Old 03-10-2012, 10:39 PM   #21 (permalink)
Ladogaboy - '11 Mitsubishi Lancer EVO GSR
Team Emperor
90 day: 27.64 mpg (US)
E85 EVO - '11 Mitsubishi Lancer EVO GSR
90 day: 21.38 mpg (US)
Removal can be difficult if the screws holding the mirror on have been "Lock Tighted" or had some other adhesive applied. You might need to use a penetrating oil and use a hammer to loosen the screws before you try to unscrew them. If you strip the heads, you're screwed... :-/
Old 03-10-2012, 11:59 PM   #22 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I did a mirror delete today using the MI-141 mirrors.
Before.
After
Inside mirror views. I used screws to mount the mirrors.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
The Following User Says Thank You to SentraSE-R For This Useful Post:
Opium (02-26-2015)
Old 03-11-2012, 01:20 AM   #23 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
how is the viewing?
I want to do this with the MI-141 and do the aero mirror mod.
http://ecomodder.com/forum/showthrea...ors-19748.html
Old 03-11-2012, 04:59 AM   #24 (permalink)
Originally Posted by JPD View Post
Hi, I like your mod, I was wondering whether you removed the mirrors yourself? Is it difficult to do? Also, do the internal mirrors give the same field of vision as the wing mirrors?
Thanks
Hello, it was very easy to remove my mirrors by myself. The internal mirror gives a view mostly of the blind spot. If you use the internal mirrors along with your rear view mirror you will do fine.
Check these pics out so you can have a idea of the view.
http://ecomodder.com/forum/attachmen...4&d=1331096296
http://ecomodder.com/forum/attachmen...6&d=1331096429
Old 03-11-2012, 05:00 AM   #25 (permalink)
[QUOTE=SentraSE-R;292704]I did a mirror delete today using the MI-141 mirrors.
Before.
Great!!!!
How did you screw the mirrors in? Can u also take a pic of an angle where the screw on the mount is showing please? I wanted to do that since my surface is not flat.
Old 03-11-2012, 05:03 AM   #26 (permalink)
Originally Posted by deathtrain View Post
how is the viewing?
Check the pics of my viewing from the driver side.
Old 03-11-2012, 11:28 PM   #27 (permalink)
I got lucky that I have two Auto zones in town, both just had one. That double sided tape sucks. So when I get ready to make the areo mirrors I will just glass them in on the inside cap.
Old 03-12-2012, 12:10 AM   #28 (permalink)
Pishtaco
SentraSE-R's Avatar
Here's how I screwed the mirror on.
And here's what it looks like from the side. My inside trim piece is curved, too.
Darrell
The Following 3 Users Say Thank You to SentraSE-R For This Useful Post:
cfg83 (03-12-2012), deathtrain (03-12-2012), Opium (03-14-2012)
Old 03-12-2012, 08:27 PM   #29 (permalink)
Pishtaco
SentraSE-R's Avatar
In case anyone questions the safety of those little mirrors, here's my rear/side views.
Darrell
Old 03-14-2012, 06:47 AM   #30 (permalink)
So do you have two of the front mirrors?
