Old 10-19-2011, 01:24 PM   #1 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
echo gear ratios
today i found that my fift gear ratio on my 05 toyota echo was 0.815.
i wonder if its safe to change my for the tercel 95+ fift gear that is 0.725
or eaven the last gear of the toyota echo auto trans that is 0.700?
Old 10-19-2011, 01:37 PM   #2 (permalink)
Chances are the gear is machined into the shaft and you won't be able to just remove it. To find that out you can pop the cover off the end of the transmission (closest the driver's side wheel) and take a peek.
Old 10-20-2011, 12:25 PM   #3 (permalink)
40-60-40 MPH P&G
is it safe to change the fift gear?
Old 10-20-2011, 02:00 PM   #4 (permalink)
40-60-40 MPH P&G
today i call trans specialized garage and they say that my fift gear ratio was 0.725 but everywhere i look on the net it says that my fift gear ratios is 0.815. who is wrong? i hope its 0.815 and not 0.725
Old 10-20-2011, 06:39 PM   #5 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z
90 day: 49.05 mpg (US)
When the clutch on my Echo will be replaced in the foreseeable future, I will definitely look into swapping the 5th gear for lower revs on the highway.
I will be following this thread closely and contribute in any way that I can.
Old 10-20-2011, 07:11 PM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
with a manual trans you can put it in 5th (ignition off) and roll it forward one tire revolution and note how many degrees the engine turned (or vice versa) and figure out the overall ratio for any gear that way. Might take a little bumping/rocking, but it can be done by hand and quickly.
Old 10-23-2011, 08:57 PM   #7 (permalink)
40-60-40 MPH P&G
maybe there is a tercel 95+ owner that know is rpm at 50mph
me its between 2100 and 2200 rpm
i realy want to know if i have the same fift gear ratio of a 95+tercel
Old 10-23-2011, 10:05 PM   #8 (permalink)
See if this helps. I think the best tranny is in a Japan only version. I looked it up when I had my Echo, which was about 2600 RPM at 60 MPH, sadly.
Toyota C transmission - Wikipedia, the free encyclopedia
regards
Mech
Old 10-23-2011, 11:41 PM   #9 (permalink)
40-60-40 MPH P&G
i found my tranny:Toyota C transmission - Wikipedia, the free encyclopedia
and the tercel tranny is just after and its says what y was saying before
but its not only the tercel that the fift gear is 0.725 maybe the toyota owner can take a look at this page and find if they have a 0.725 fift gear and then tell me what are their rpm at 50 55 or 60 mph and i will compare
Old 10-24-2011, 12:00 AM   #10 (permalink)
CigaR007's Avatar
Question is, are the 5th gears interchangeable between the C150 and C151 transmissions ?
I must admit that a lower RPM in 5th gear would provide an even better fuel economy.
tercelguy could be of help to us : Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - View Profile: tercelguy
