Old 06-28-2012, 01:28 AM   #11 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
The Following User Says Thank You to Vekke For This Useful Post:
Diesel_Dave (06-28-2012)
Old 06-28-2012, 09:04 AM   #12 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Originally Posted by OziDarklighter View Post
I like the idea of taking a stock El Camino and changing out minor parts to increase fuel economy, but I'm still not sure that 30+ is achievable. Thoughts??
Well, I get 30+ in my truck, which is much heavier and has much worse aero (Cd*A) than an El Camino, so it's definitely achievable--it's just a question of difficulty.
Isn't it a bit counter-intuitive that you'd want to put in a heavier engine (700+ pounds) in order to achieve a more efficient result though?
Not necesarily. The weight difference between engines would only be ~100-200 lbs. That's not really a big difference--equivalent to having somebody in the passenger seat. Heck, my 35 gal fuel tank weighs ~250 lbs. Curb weight for that El Camino is probably about 3,500 lbs, so an additional 200 pounds is only a 6% increase in total weight. That will increase the rolling resistance by 6%, resulting in a fuel economy penalty of something less than 6%. So if the new, 200 lb heavier engine is >6% more fuel efficient, then you're gauranteed a net positive.
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
Old 06-28-2012, 09:52 AM   #13 (permalink)
My solution:
The Following User Says Thank You to silverinsight2 For This Useful Post:
Sporty Modder (06-29-2012)
Old 06-28-2012, 10:10 AM   #14 (permalink)
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
Well, if the weight offends you, a Benz OW617 engine would weigh about the same as your small-block and give you good mileage and outstanding durability.
30 MPG would be a snap for it. And no cantankerous EPA-limited electronics.
BUT...the acceleration would be terrible, even by eco-modder standards and getting a manual transmission to fit probably involves a trip to Germany.
Maybe, it you never load it much a VW TDI engine might work.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
Old 06-29-2012, 03:11 PM   #15 (permalink)
Doug - '03 Chrysler PT Cruiser Base
90 day: 31.16 mpg (US)
DR 350 - '92 Suzuki DR 350 S
90 day: 61.09 mpg (US)
Sid the Sloth - '82 Honda Civic CVCC Wagon
Last 3: 35.93 mpg (US)
Rocky - '92 Daihatsu Rocky
Last 3: 24.97 mpg (US)
Mick - '97 Jeep Cherokee XJ UpCountry
90 day: 19.4 mpg (US)
Tell us what year El Camino are you looking at and we will be able to help you out a lot better.
El Caminos get much better than 12mpg on the upper end depending on which year/engine combo.
Old 06-29-2012, 06:39 PM   #16 (permalink)
How about a little four-banger with a turbo?
-soD
Old 06-29-2012, 08:08 PM   #17 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
Here you go... Chevrolet El Camino - Wikipedia, the free encyclopedia
IRCC the el Camino weighed 4000 lbs. It also had a factory 3.3 l engine with 95 hp.
A Nissan Ka 24{2.4l 4cyl) had 130 hp sohc and 150 hp dohc. Also came in rwd chassis 240sx.
Old 06-29-2012, 08:50 PM   #18 (permalink)
NightKnight
NachtRitter's Avatar
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 54.39 mpg (US)
Mathilde - '99 Volkswagen Eurovan Camper
90 day: 16.87 mpg (US)
A stock VW TDI has ~90 hp and can be (relatively) easily be bumped up another 30 or more hp... so seems like a good match power-wise. Of course, it wouldn't be a straightforward swap (FWD to RWD, electronics, etc) but there are quite a few examples on the interwebs (Easy Jeep VW TDI Diesel Swap | Editorials Blog & Discussion at Jp Magazine (caution, ads!), 85 4runner VW 1.9 AFN M-TDI swap - YotaTech Forums, TDI Conversions - TDIClub Forums)
Old 06-30-2012, 10:33 AM   #19 (permalink)
2.5L GM gasoline engine used in a variety of vehicles in the 80's. Easy swap bell housing, mounts, wiring make it doable with minimal custom fabrication. Engine can be modified to give decent performance and fuel economy.
Old 06-30-2012, 08:50 PM   #20 (permalink)
First off, Ecomino has a much nicer sound to it.
From the OP's post, I gather he doesn't have a ton of money to blow at this time and he needs reliable transpotation that gets decent mileage.
Personally, I don't really "get" the El Camino, but, to each his own.
The trouble is that one of these things that is in good enough shape to drive every day is likely to cost more.
I think your best bet at this time is to find a decent running Ranger/S10 4 cylinder 5 speed. Such vehicles can get into the 30s with a little hypermiling/mods.
And start saving your pennies.
Some day, you'll have the coin to buy a nice old El Camino. I would suggest you get one from the 60s, early 70s, as they are much cooler, IMO. Of course, it would have to have a 396 4 bbl.
So much for eco!
The Following User Says Thank You to pete c For This Useful Post:
slownugly (08-03-2012)
