Old 01-04-2011, 07:55 PM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Question Eco-friendly fiberglass resin ??
So is there such a thing as an eco-friendly fiberglass resin ??
( Had to ask. )
And what would be an alternative to using fiberglass resin that is not so toxic ?
Old 01-04-2011, 08:43 PM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Epoxy resin is a much lower VOC, much less toxic alternative to polyester resin. It's also compatible with styrofoams, which polyester resin is not. I've used it successfully.
The Following User Says Thank You to RobertSmalls For This Useful Post:
Cd (02-05-2011)
Old 01-04-2011, 08:53 PM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
And masterfully too I must add.
Old 01-04-2011, 09:14 PM   #4 (permalink)
Left Lane Ecodriver
Thank you, and I like my work too, but it's quick and dirty, instead of masterful. I could spend a bit more time and get a smoother mold and a better surface finish. I could also vacuum bag things and get lighter composites.
I'm sure you've seen 3-Wheeler's fiberglass boat tail and motorcycle fairings. He has many tips to share on working with fiberglass.
I forgot to mention that I get my epoxy and glass cloth from USComposites.com, and they're a great source for such things.
Old 01-04-2011, 11:43 PM   #5 (permalink)
sid
grayranger - '10 Ford Ranger XL 2 door supercab
90 day: 31.85 mpg (US)
I also prefer epoxy resin and have used over 15 gallons of it over the years on many projects. I prefer West Systems epoxy. It is expensive, but I get better results than with the other epoxies I've tried. I've used it successfully with wood, fiberglass, Kevlar, and carbon fiber.
2010 Ford Ranger, extra cab, 2.3 liter
http://www.stonemarmot.com
Band's latest song/music video "I Sing Along"
Old 02-05-2011, 01:55 AM   #6 (permalink)
I have been thinking of the resin that is used for casts these days, it used water as a catalyst. with polyester it is the catalyst that is really bad.
Old 02-05-2011, 06:42 AM   #7 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
I'm not sure what eco-friendly means in terms of using a chemical product like polyester or epoxy resin.
From the user point of view, probably the most eco-friendly thing that you can do is to learn to use as little adhesive as possible and still get the job done. Avoid coating surfaces with epoxy and use as little glass as much as possible. Having said that, glass and epoxy is an amazing building material.
I get my boatbuilding epoxy from raka.com, it is cheap and a high quality product.
Nissan Versa Aeromods
The Following User Says Thank You to skyl4rk For This Useful Post:
Cd (02-05-2011)
Old 02-05-2011, 12:11 PM   #8 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
I've used Raka epoxy as well, I like using thin ply wood with epoxy and fiberglass coating the outside, it makes for a strong sandwitch that is pretty cheap to build.
Old 02-05-2011, 05:55 PM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
you might think about some organic building materials/methods, I thought there were some japanese ww2 planes made from bamboo and silk, non structural compund curves are pretty easy in paper mache, I don't know the environmental impact of white glue but it works as fuelproofing in model airplanes as well as a good binder and is dirt cheap. Just thinking out loud here, I'm sure there a million options though some associated learning curve/trial and error.
Old 02-05-2011, 08:40 PM   #10 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Thanks for thinking ' outside the box ' on that last post.
I just watched a show on an exotic top secret flying wing aircraft from WW2 called the Horten 229 .
Most of the aircraft was made from wood, and compound curves were done using thin sheets of flexible wood paneling , with bolts and wood glue holding it together.
Simple wood putty can also be used to form smooth edges and curves.
Balsa wood is extremely light.
eco friendly, fiberglass, fiberglass resin
