Old 07-02-2008, 01:02 AM   #1 (permalink)
Boy Blue - '93 Jeep Cherokee Country
90 day: 18.55 mpg (US)
Jeep intro
Hey all, a 1993 Cherokee owner here to introduce myself. Just recently found these forums and started reading up, and want to try to meet a fuel efficiency goal. Current EPA combined efficiency (from Fuel Economy) is 15 mpg for my auto 4.0L 6 cyl. I know that I can pull 16 - 18 mpg already just having been doing less aggressive driving already for some time. I'm hoping that with some more work I can try to push to 25 mpg combined or more!
Some things to do:
- Checked tire pressures, average around is about 33 psi (tire rated to 44 psi). Will inflate these to 40
- Removed window guards, those things that let you crack the window and not get rain in (caused lots of wind noise I realized, and probably decreased aerodynamics)
- Will remove roof rack
- Will block part of grill, and some areas around front
- Rear wheel skirts(?)
- Repair bumper: I have a big dent in it from a small bumper buster, probably the biggest killer currently
Some things I know I am curious about
- using 5W-30 instead of 10w-30, or even a thinner synthetic brand
- Acetone?
- I had the crazy idea for building a switch-deployable boattail, as well as a possible front mod to improve the curve over the hood out of clear plexi or lexan (would require some work definitely)
Jeep: 25+ mpg or bust
Old 07-02-2008, 02:33 AM   #2 (permalink)
Red
Red's Avatar
Welcome to EM. Good to see another Jeep owner
Old 07-02-2008, 10:34 AM   #3 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
First off welcome. Seems more and more Jeep owners are interested in saving money at the pump.
I've been running 5W-30 in my Cherokee for a couple of years now. Haven't had any problems. Seems like after switching it starts better in the winter. One mechanic I talked to said there isn't a huge difference between them anyway.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 07-02-2008, 02:28 PM   #4 (permalink)
Red
Red's Avatar
Nah plus the 4.0 would lube fine on sludge............
So long as it vaguely resembles oil, the 4.0 doesn't care.
Old 07-04-2008, 10:14 PM   #5 (permalink)
Most my jeeping buddies own Civic's or Integras, or Metros. We've found that's a much better way to get better economy from our jeeps. I filled my jeep about a month ago.
Mine's on 6" of lift with 33's and regeared axles. I get around 12-15 with it.
Be careful blocking off the grill, Cherokee's have a very limited cooling system, and you don't want to overheat it.
Glides like a Brick Wall (Jeep Cherokee, GMC Pick-up) DonEaston Aerodynamics 22 10-26-2008 04:17 PM
jeep aero mod ideas johnpr Aerodynamics 22 08-27-2008 07:45 PM
Squeezing MPG's out of a Jeep - or atleast trying. RoboMike EcoModding Central 56 07-01-2008 10:22 PM
Jeep on a Diet 2001Jeep EcoModding Central 8 06-09-2008 09:40 PM
Off-Road Test: '08 Jeep Grand Cherokee (Rally Race) RH77 The Lounge 4 02-25-2008 03:59 PM
