Old 09-09-2021, 08:45 AM   #81 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Torque converters can be made robust for towing, especially with extra cooling.
The problem is all that slippage causes heat, and the transmission fluid loses its properties once it heats above a certain temperature.
I wonder if Toyota's eCVT could scale up to semi truck size and actually be more efficient with a hybrid setup? No gearbox, and always in the right "gear".
I'm fairly certain the answer is yes and already been done. Check out the GM 2 mode hybrid trucks, they're based on technology by Allison that I believe was used in several city bus models. I don't have time to research it right now so I hope my memory is serving me correctly.
Old 09-09-2021, 04:20 PM   #82 (permalink)
Aerodynamic drag.
Not sure to which extent a boat trailer would be absolutely better than some others, such as an Airstream or some oversized teardrop-trailer, but OK.
Old 09-17-2021, 10:19 PM   #83 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
Update: Nothing sounded good to me so I decided to reserve a F150 Lightning! It might not be the cheapest, but it is definitely the most economical and efficient for many other reasons.
The Following User Says Thank You to Taylor95 For This Useful Post:
Isaac Zachary (09-17-2021)
Old 09-17-2021, 10:24 PM   #84 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Hey! Whatever tows your boat!
Old 09-19-2021, 05:13 PM   #85 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
You definitely need to keep us updated once you get it.
