Finally made wheel skirts that are permanent yesterday! No more hearing them rub the tire if a vehicle gets too close
This is a simple process that can add a lot of life to your skirts. I went the more expensive route, but it is worth it to me.
Removed old wheel skirts that were held on with duct tape
These are the items used to fasten the new coroplast down. These tabs and 1/4" aluminum bar can be found at Lowe's. I spent ~$12 on this.
Next came measuring the width of the wheels wells. Roughly 30" for the ZX2. The ends are hand bent to fit, making sure they clear the tire at all times. Next, I used 1" screws with a 5/16" head to screw them in place, along with the tabs.
Next is cutting the coroplast to fit
WELL. This took longer than I expected, and the time is worth it. Paint them with whatever color you want. I chose black. Screw them down and you have some bangin' lookin' covers now!
Beautiful and functional
