Old 12-12-2010, 12:02 PM   #221 (permalink)
The "Crower" thing sounds neat and all, but it was patented in 1920 by someone else. That it's been around 90 years and never made it out of the lab begs the question of why?
http://www.freepatentsonline.com/1339176.pdf
Old 12-12-2010, 12:36 PM   #222 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
It is a good point, that the secondary cycles should not increase the backpressure, as that directly affects the work the pistons have to do. Heat exchangers usually involve some energy losses.
Given the pitiful energy density of hydraulic and power to weight of sterlings (think lots of little sterlings with plenty of surface area connected to a hydraulic cvt), it is looking like the most "feasible" highly efficient vehicle is going to be a (hopefully streamlined) fatass, on two wheels
Old 12-12-2010, 11:09 PM   #223 (permalink)
So, why do piston / connecting rod / crankshaft designs seem to hit the efficiency wall at 38%? What is holding them back from getting closer to the 54% theoretical limit? The beginning of this thread has about three new rotary designs -- do any of them look to exceed 40%?
Old 12-12-2010, 11:25 PM   #224 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
You seem to be caught on the 38% number, but what of the ones that are rated higher? How about the VAG engines from VW and Audi? And why does the efficiency of very large engines exceed that of smaller ones? Here is a related question to that... Why will a 3 cylinder 1.2l typically have a better thermal efficiency than a 4 cylinder of same size? I would say that there has been a good amount of discussion on why we havent seen this 54% theoretical efficiency, and I dont know what you are looking for in our answers as this is at least the second time you have asked this after getting many answers.
Old 12-13-2010, 11:18 AM   #225 (permalink)
What piston engines are higher than 40% efficient in the real world? How long do they take to warm up? Can they have some sort of cogeneration cycle added on that significantly improves that?
Old 12-13-2010, 11:32 AM   #226 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
hey, I can answer that:
DIESELS!
Brake specific fuel consumption - Wikipedia, the free encyclopedia
I'm not coasting, I'm shifting slowly.
Old 12-13-2010, 01:19 PM   #227 (permalink)
What is the most efficient diesel engine?
Obviously, biodiesel would avoid the massive penalty of wasting the majority of energy; because it is short-cycled energy and since it is renewable, it doesn't upset the balance of carbon in the atmosphere.
Old 12-13-2010, 07:13 PM   #228 (permalink)
Neil, do you refuse to read the links provided?
Old 12-13-2010, 08:00 PM   #229 (permalink)
Nope, just missed it...
So, the VW TDI V8 (?) and the Audi TDI are most efficient car engines, then? Do diesels have Start/Stop tech?
Do the EPA rating for diesels take into account the higher BTU's per gallon of diesel?
Old 12-13-2010, 08:16 PM   #230 (permalink)
So, if the EPA uses mpg for both, but uses mpge for electric, one could conclude that they do not account for the energy density difference. That is their efficiency at constant operation, not using engine stop/start tech.
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 01:17 PM
The Easy Leg: Vehicle Efficiency natefish Off-Topic Tech 17 05-19-2010 04:52 PM
Vehicle Efficiency Improvements SVOboy EcoModder Blog Discussion 24 12-07-2009 10:19 PM
World’s cleanest internal combustion engines? blueflame EcoModding Central 6 02-28-2009 08:13 PM
Low-Drag Trucks: Aerodynamic Improvements & Flow Control System Boost Fuel Efficiency OokiiMamoru Aerodynamics 5 06-15-2008 11:38 PM
