Old 09-17-2008, 11:05 AM   #1 (permalink)
GreenMile - '00 Mazda Protege ES
90 day: 34.45 mpg (US)
Efficient alternator modification?
Hi guys
I'm new to this forum and new to ecomodding but I have spent a lot of time lately reading about different modifications to improve efficiency.
My idea is not running the alternator directly off the engine but instead running it off an axle or a drive shaft. The alternator would either be built around it or conversely slipped over one of those.
The reasons for such a mod would be that the alternator could be used to recharge the system in a regenerative breaking type set up.
The main complication I see that it may not be feasible to depower the alternator when charging is not needed, in which case I would see this modification as being extremely ineffiecient as it would reduce power to the wheels.
I will post more on this later, thanks for the ideas
http://benw385.vox.com/
'Blog' on the open source electric motorcycle project.
Please come visit and comment!
Old 09-18-2008, 07:06 AM   #2 (permalink)
Tracy - '00 vauxhall corsa
thats a cool idea. would be good if you could make it suck enough power out of the vechicles momentum to slow it down to a stop. maybe a standard alternator could be geared up to produce a higher voltage/amps. you would probably need to find the most powerful alternator you can find as the power involved in stoping a vehicle is large and might melt a regular motor/alternator. it would be easy to cut the electrical load when braking is not required -the easiest way to control it.
high charging amps are not ideal for lead batteries though.
Nissan Leaf 24kwh. Average FE = 300mpg 3.6miles/kwh (@plug)
Teaching Efficient Driving in School 93DelSol Hypermiling / EcoDriver's Ed 17 06-05-2010 09:49 PM
fuel efficient, reliable used cars under $3k auto General Efficiency Discussion 36 05-30-2009 02:00 AM
Looking for a fuel efficient solution. I've got a few ideas. CuriousOne EcoModding Central 41 03-28-2009 02:46 PM
Big Surprise: Fuel efficient cars are holding their value better than other cars SVOboy EcoModder Blog Discussion 2 09-19-2008 08:52 AM
Which would be more fuel efficient? wwkayaker Aerodynamics 7 08-16-2008 12:52 PM
