Old 03-25-2010, 02:46 PM   #1 (permalink)
My Goal: 35 MPG All Day
RandomFact314's Avatar
1NZ-FE (Year 1) - '05 Scion xA RS 2.0
Last 3: 34.02 mpg (US)
1NZ-FE (Year 2) - '05 Scion xA RS 2.0
90 day: 33.32 mpg (US)
1NZ-FE (Year 3) - '05 Scion xA RS 2.0
90 day: 35.32 mpg (US)
1NZ-FE (Year 4) - '05 Scion xA RS 2.0
90 day: 34 mpg (US)
1NZ-FE (Year 5) - '05 Scion xA RS 2.0
90 day: 26.87 mpg (US)
1NZ-FE (Years 6,7,8) - '05 Scion xA RS 2.0
90 day: 28.6 mpg (US)
1NZ-FE (Years 9,10,11) - '05 Scion xA RS 2.0
90 day: 27.8 mpg (US)
1NZ-FE (Years 12,13,14) - '05 Scion xA RS 2.0
90 day: 29.13 mpg (US)
Anyone have ideas on how to accomplish this mod:
Not the top grill block or the head light thing but the bottom of the bumper...
I want to make it flat like in the ghetto-photoshop I did...
I want to do something like this and have some cash to spend but would like to keep it cheap-er... Would just screwing coroplast into the bumper and painting it silver be the best way or is there anyway I can heat up the bumper enough to shape it?
Sounds crazy to heat up the bumper to shape it but W/E
Or is this way to much blockage?
Old 03-25-2010, 03:07 PM   #2 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
You might be able to find "kick panel" trim in a close to matching grey at Lowe's or Home Depot. It's like $4 for 3 to 6 feet of flexible rubber that's 4" or 6" tall. I forget the exact name, and can't seem to find it via search.
Old 03-25-2010, 03:12 PM   #3 (permalink)
90 day: 34 mpg (US)
It would be awesome to block that much of my grill off, I want to start a belly pan too but just up under the front bumper, Just worried about using coroplast cuz that might sag or rip off
Old 03-25-2010, 05:19 PM   #4 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
Two layers of Coroplast can be glued together with beads of Silicon Seal. It takes a while to dry, but gives a very rugged panel. It also makes it easy to make seams and hold curves. There is also a heavy-duty, thicker Coroplast.
The Following User Says Thank You to Bicycle Bob For This Useful Post:
mcrews (03-25-2010)
Old 03-25-2010, 05:58 PM   #5 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
RandomFact314 -
I forgot his name, but there's the dude that did the awesome side mirror deletes and the front foglight covers for his Civic (hatch?).
I don't think that will cost much $, but I it will cost time. Sooooooo, it depends on what you have more of, punk! (as Dirty Harry might say)
CarloSW2
American Solar Energy Society
Old 03-25-2010, 06:33 PM   #6 (permalink)
Big Daddy Roth would have used plaster to seal and smooth, then fiberglass over it.
mcrews (03-25-2010)
Old 03-25-2010, 06:57 PM   #7 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
I still like my shrink wrap plastic. $1.68 at Lowes. It is the stuff you put over your house windows in the winter with double sided tape and then shrink with a hair drier. Since it is clear no need to paint. I put mine on in the begining of winter and still on there. I need to attack it again with a hair dryer since some of wrinkles came back. I've started watching the SG temp guage as the temp warms up. I'm hoping to rig a cooling fan light so I can make sure I'm not overheating.
The Following User Says Thank You to busypaws For This Useful Post:
mcrews (03-25-2010)
Old 03-25-2010, 09:54 PM   #8 (permalink)
Altee - '00 Nissan Altima GXE
90 day: 31.82 mpg (US)
I thought about doing something similar. My plans was to buy a second used bumper and stretch fabric over the inlet. fiberglass over it sand, prime and paint.
Old 03-25-2010, 10:06 PM   #9 (permalink)
Same idea...
The Following 3 Users Say Thank You to Devon Hynes For This Useful Post:
cfg83 (03-26-2010), Nevyn (03-26-2010), RandomFact314 (03-25-2010)
Old 03-26-2010, 11:24 AM   #10 (permalink)
White Liner
1.Clear packing tape on the outside. 2.expanding foam in a can. easy if the bumper is removed but if you can get at it from behind it's that much faster. 3.let dry a few days, remove tape and trim off excess foam. 4. Fiberglass coat it.
Engine/ECU mod ideas for mileage jcantara EcoModding Central 11 04-30-2010 05:22 PM
Requesting aero mod ideas (pickup: dodge ram 2500 4x4) nubbzcummins Aerodynamics 7 12-31-2009 12:41 AM
Testing the IAT mod tasdrouille General Efficiency Discussion 6 09-27-2009 04:09 PM
Mod ideas for Monte Carlo saunders1313 Aerodynamics 2 09-19-2008 09:24 AM
jeep aero mod ideas johnpr Aerodynamics 22 08-27-2008 07:45 PM
