Old 10-18-2010, 08:50 PM   #181 (permalink)
Basjoos Wannabe
ShadeTreeMech's Avatar
The Van - '97 Mercury Villager gs
90 day: 19.8 mpg (US)
Lyle the Kindly Viking - '99 Volvo V70
90 day: 25.82 mpg (US)
the giant washer is going on the idler pulley? be sure to bevel the edges if you do this.
You might have your machinist friend help you figure out the alignement issue. It could be your idler pulley causing the issue.
RIP Maxima 1997-2012
Originally Posted by jamesqf View Post
I think you missed the point I was trying to make, which is that it's not rational to do either speed or fuel economy mods for economic reasons. You do it as a form of recreation, for the fun and for the challenge.
Old 10-19-2010, 12:40 PM   #182 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
I just thought to make it a little easier to check the angle of the idler pulley use a gap feeler like for spark plugs. Use it to check the distance between the plate and the pulley look on different sides and see it the gap is the same.
I know that you could not fit a smaller belt on there but I can't help but think that it needs to be tighter. Does that engine have an idler tension pulley at all on it?
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 10-19-2010, 09:32 PM   #183 (permalink)
A madman
brucey's Avatar
Pequod - '17 Subaru Outback
90 day: 22.79 mpg (US)
Send a message via AIM to brucey
Phantom: If you're referring to the last picture, the belt isn't tensioned there. The only tension on the belt is from the alternator.
Old 10-20-2010, 12:33 AM   #184 (permalink)
3dplane's Avatar
14 Mirage - '14 Mitsubishi Mirage DE
90 day: 68.74 mpg (US)
Can you stick some kind of straight edge down there against the side of the pulleys?
That should indicate where the angle problem is located. I know your custom pulley is double wide but it would still show an angle difference in relation to the rest of the pulleys.
( if there is room! )
Old 10-20-2010, 07:33 AM   #185 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
a $3 laser pointer might be helpful too, for alignment.
Old 10-20-2010, 06:58 PM   #186 (permalink)
A madman
brucey's Avatar
Good news everyone! Finally fixed the pulley walking. I added some angle to the idler pulley and the walk went right away. Maybe it was the problem all long. Took it for a quick drive around the block, but didn't have time to get too good of a test of the belt since it's mid-day traffic currently.
The only problem now, is I'm getting a slight bit of noise in the AC12 motor pulley. Probably from where the shaft had to be ground on. I plan to fix this by simply drilling and tapping the end of the shaft and having a bolt hold the assembly in place with an extra sleeve that the pulley guy made.
One last thing. I realized only JUST NOW that the pulleys are not lined up from the factory. They're spaced about a rib apart between the crank, power steering, and alternator. I wonder if this had something to do with why I couldn't get them to line up properly, as I was lining them up based on a straight line between the 2 pulleys and carrying it on.
Old 10-26-2010, 01:09 PM   #187 (permalink)
Basjoos Wannabe
so........
how's it going?
Old 10-26-2010, 06:02 PM   #188 (permalink)
A madman
brucey's Avatar
No real updates. I needed a bit of a breather after the headache that was getting the pulley walk to stop. Catching up on other things now. I don't plan to do much on this project until after this weekend.
Old 11-04-2010, 11:55 PM   #189 (permalink)
A madman
brucey's Avatar
Just a quick update on this:
I still plan to get most of the parts connected to the car within a week. It's just a matter of finding the time. I worked on the pulley some more today, drilled a whole and need to tape a shaft so that I can put a bolt on it and lock the pulley in place. It slightly rattles currently and that's not acceptable to me.
But I've decided to put the controller inside the car, underneath the driver seat for the time being. I'm hoping there it can get enough air but still be protected from the sun and foot traffic. Once that's in, I can measure the amount of wire I need and hook everything up.
Hopefully that and some batteries and I'll be in the proof of concept stage.
Old 11-05-2010, 06:08 AM   #190 (permalink)
Ford Escort 2.0
TomEV's Avatar
Electricar - '89 Ford Escort LX Hatchback
Depending on the controller you have, and the amount of power you require, it might not put out much heat.
I have an Alltrax 7245 mounted on a piece of 1/4" aluminum about twice the size of the controller.
In my application, it is generally lightly loaded during cruise speed (about 6kW) and does not get much more than 20 degrees F above ambient temp.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 01:21 AM
Electric assist for SUV? Tony Raine EcoModding Central 8 10-15-2012 09:17 PM
Electric sailboat motor: new conversion project (update: project shelved) MetroMPG Fossil Fuel Free 51 07-25-2012 11:21 AM
DIY hybrid (detailed noodling of crankshaft-mated electric assist method) NiHaoMike Hybrids 16 03-03-2012 06:41 PM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 11:41 PM
