Old 12-30-2008, 11:39 AM   #1 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Electro-Metro New Efficiency record
This morning was the first time I have tracked both my trip miles and the energy to recharge, since I have installed the new coupler
Converted, it equals 134.8 Miles per Gallon!
Oh yeah, and that's all on RENEWABLE energy!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 12-30-2008, 01:51 PM   #2 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Nice! Only time I get 134 MPG is coasting in Neutral on the highway
Old 12-30-2008, 03:04 PM   #3 (permalink)
90 day: 57.73 mpg (US)
Considering you achieved your record in cold winter conditions where battery performance is reduced, and rolling, mechanical and aero resistance is increased, that's nothing to sneeze at. Nice going.
Old 12-31-2008, 04:55 PM   #4 (permalink)
Silver Turtle - '02 Ford Focus Zx3
90 day: 38.83 mpg (US)
What changes did you make? Or only driving habits?
Old 12-31-2008, 07:08 PM   #5 (permalink)
EV test pilot
bennelson's Avatar
S10 - '95 Chevy S10
I've been accelerating less harshly, my front batteries are insulated with 2" of extruded pink foam insulation, and I have a nice solid transfer of power from the motor to the transmission.
I have also been shifting more. I actually use first gear every once in a while.
A good part of the summer, I just drove in third. It was so easy to drive like an automatic. Shifting is a little more work, but a little more efficient too.
My YouTube Videos
Old 12-31-2008, 10:26 PM   #6 (permalink)
I've also read in multiple places that an e-motor is most efficient at cruise when spinning around 3-4k rpm.
If I had it in a higher gear to get more amps for acceleration, I'd often pull it back down a cog or two to cruise along.
But for max efficiency, I also used 1st gear from a stop and accelerated lightly.
Old 01-01-2009, 12:38 AM   #7 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
That's what I've seen too. Higher rpm/lower power tends to be more efficient, kinda the opposite of ICEs.
Old 01-01-2009, 02:06 AM   #8 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I wonder if anyone ever considered using a CVT type transmission for this app? You can tune some of those transmissions so that they keep a specific input RPM through acceleration... so basically, you could set it up so that the e-motor is ALWAYS at whatever RPM you want it at, other than initial power up to start moving... but as soon as it gets going fast enough in the lowest "gear ratio" of the CVT setup to be at your prime speed, the CVT starts expanding the output to update the ratio dynamically based on input speed.
The easiest example of this I can think of is on a field vehicle that my dad used to have called a "PUG". Articulate steering and a 5HP motor, 2 speed axle, but a centrifugal clutch on the motor and a centripetal drive pulley on the axle input. (belt driven)
It would dynamically change ratios for a few seconds. High gear was RPM limited to 25 MPH, which is great for a 5HP briggs,, especially in a 500lb vehicle with 1000lb capacity in the back and 500lb cap up front, for a total of 2000lbs capacity... it would still go 25 MPH fully loaded down.
Old 01-01-2009, 07:32 AM   #9 (permalink)
Hi Ben,
What factor(s) are you using to convert kWH to gallons of gasoline?
Metro taller transmission swap thread: +5% efficiency gain (taller final drive) MetroMPG EcoModding Central 36 02-11-2015 12:08 PM
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 44 12-09-2014 12:22 AM
Geo Metro convertible / Kubota diesel engine conversion (driving!) kimer6 EcoModding Central 118 07-01-2013 05:21 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Getting more efficiency out of a ZX2. Small list of mods and driving tips for it. koihoshi EcoModding Central 9 07-20-2008 05:26 AM
