Old 03-03-2013, 07:35 PM   #1 (permalink)
Secret Weapon Intake for Echo
Anyone try this?
Old 03-03-2013, 07:38 PM   #2 (permalink)
Always Too Busy
Flakbadger's Avatar
White Lightning - '17 Nissan Leaf SV
Team Leaf
90 day: 159.47 mpg (US)
I'm assuming you're talking about this thing, which pretty much just looks like a cold-air intake to me.
My instinct is that it's B.S., as most fancy-dancy intakes are usually 20% science and 80% false claims.
Current Car: 2023 Chevy Bolt EV
Retired Car: White Lightning
Retired Car: Betty White
Old 03-03-2013, 07:45 PM   #3 (permalink)
Hmmmm.... I run a poked airbox and a K/N on my bike, it's noticeable. Slight but noticeable.
Old 03-03-2013, 09:33 PM   #4 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
You will see a better result from improving aerodynamics, I ended up removing my WAI because the engine was retarding the timings when I had to stop (It has been in the 80's where I live)
I did an upper grill block and fixed my panel gaps to compensate for any FE loss.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
Old 03-03-2013, 10:28 PM   #5 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
maybe you could search......
since this issue is covered many times.
It's just an aftermarket air intake with a cone filter. Try searching any of those words.
They only work at WOT. And how often are you at WOT?
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 03-04-2013, 01:17 AM   #6 (permalink)
mechman600's Avatar
Fusion - '16 Ford Fusion Hybrid SE
This would work better:
New Electrical Turbo Charge Turbo 5000 330W | eBay
Old 03-04-2013, 01:42 AM   #7 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Just to be clear, when operating normally, your throttle is mostly closed to form a very small opening to the intake manifold. It is by far the most restrictive thing in your air induction to the pistons. So creating a "freer flowing" system up stream will do nothing to improve airflow at the 10-20% power which is where you operate 95% of the time. Any claims of better mileage are not supported by reason and will not be seen in real life. As others have said, reach for lower hanging fruit if you're looking to achieve better fuel economy.
Old 03-05-2013, 02:27 PM   #8 (permalink)
Talking
A Header would kill mileage then?
When I have time, the Air Dam block looks easy enough. Some heavy duty tape.
Got rid of the head rests
