Old 09-02-2011, 09:44 AM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Intake pipe selection: what do you think?
What do you think? Researching my replacement muffler because it is becoming time to replace the old one, I came across the below on intake pipes. I have been fine-tuning the WAI. The below article makes me think the optimal design would be a bit different than mine, which is a little smaller-bore than stock and about 2/3 the quite long stock length. The summation is this: "install long small bore pipes when you want power and torque at low to medium revs, long large bore pipes for mid-range torque and short pipes when you want performance at higher revs."
The Intake Pipes
Pipe Sizing Calculator
You've read it all before, the intake pipe diameter and length is very important because it affects volumetric efficiency, impinges on pumping losses, mean effective pressures, etc, etc. You have also heard of rarefaction waves, reversion pulses, syphoning, blah, blah, blah. Well guess what we actually incorporated a lot of this stuff in the calculator to make out we know what we are doing. This will also hold truw for the exhaust side of things where we claim a proper sized exhaust will suck harder than the piston itself.
Alrighty heres what we have thrown into the soup to come up with the intake pipe sizer:
Long inlet pipes increase volumetric efficieny at low speed, but decrease VE at high speed (VE is volumetric efficiency);
Mean effective pressure increases proportionally with volumetric efficiency;
The amplitude of pressure waves increase as pipe length increases;
Pressure peaks occuring around the inlet closing occur later as the pipe length increases;
Cylinder vacuum comes on later in the stroke as the pipe length increases, until the number (frequency) of pressure waves per engine cycle changes and it reverts back to the original angle and starts coming on later as the pipe continues to be extended.
Later inlet valve closing is better with long pipes and earlier with short pipes. This is because the arrival of the pressure wave is later with long pipes
Which when translated means you install long small bore pipes when you want power and torque at low to medium revs, long large bore pipes for midrange torque and short pipes when you want performance at higher revs (at the expense of losing some of your low end performance).
So what about all this pressure waves stuff you ask? Well that's simple too, because some else spent a load of some government's money when dinosaurs walked the earth and came up with some observations that you can get a whopping 15%-20% increase in mean effective pressure by just making the pipe a length that encourages a third harmonic based on the speed of sound and engine rpm. And better than that the fourth and fifth harmonic suck too!
Old 09-02-2011, 09:53 AM   #2 (permalink)
I mostly agree with your assessment. I would however keep the intake pipe long. I'm not sure how long yours is, but I don't think I'd shorten it.
Old 09-02-2011, 11:20 AM   #3 (permalink)
Cyborg ECU
The WAI is about 17-18" of smaller-bore pipe, and the stock was more like 29-30". If the WAI is smaller bore, might it make up for the shorter length? Or are these dimensions not related in that way?
Old 09-02-2011, 11:27 AM   #4 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Resonance is entirely dependent on length and not related to diameter. I'm thinking of how a brass wind instrument works. There are student models with a narrow bore (easier to play) and professional models with a large bore (requires stronger lungs but makes better and louder tone). The both make the same pitch, but the volume and quality of that note are different. I think you want the lower frequency here, which would require a longer pipe. If it gets too long you get restriction so you'll want to go fatter as well. I doubt you're going to run into that limitation here, though.
Old 09-02-2011, 11:39 AM   #5 (permalink)
I was going to say if I was going to do it, I'd want to be around 32".
Old 09-02-2011, 12:21 PM   #6 (permalink)
The Wife's Hot Rod - '09 Pontiac G8 GT
Last 3: 23.22 mpg (US)
Big Outback - '13 Subaru Outback 2.5i
Little Outback - '02 Subaru Impreza Outback Sport
I'm a little confused, are you talking about making your own intake manifold?
The intake runners they are referring to start at the back side of the valve & are measured to a point where a pressure wave would bounce off, or when the pipe opens up into the plenum, not sure which. Both of which occur downstream of the throttle plate. All the stuff from the air filter to the throttle plate really does is quiet down the intake of air.
It is possible to use first or second harmonic waves in an intake. Sometimes you can hit two usable harmonics with the same runners, just at different RPM's. If you time an exhaust harmonic in between them you can get a pretty flat torque curve as well.
An extreme example of long runners is the chrysler cross ram intake manifold
The Following User Says Thank You to DonR For This Useful Post:
California98Civic (09-02-2011)
Old 09-02-2011, 01:10 PM   #7 (permalink)
Cyborg ECU
I love this forum for exactly this kind of schooling. Can't express the gratitude. No, not my own intake manifold, just the pre filter-housing intake tube is all I mean. Would this mean in your opinion that the length and diameter of the pre-housing tube is not very significant, or just that this article is not relevant to my issue and that I have misunderstood it? (BTW, also seems like there is a mod possibility in your observation about the post throttle intake pipe.)
Old 06-27-2012, 10:17 PM   #8 (permalink)
Any updates?
Old 06-28-2012, 11:26 AM   #9 (permalink)
Smooth Operator
Old Yellar - '79 MGB Tourer Drop-Hood Coupé
Sports Cars
90 day: 25.83 mpg (US)
Old Brown Ford - '91 Ford Bronco Custom
MAGNUM - '05 DODGE MAGNUM SXT
i have thought on this and need to think more
"Longer, narrower runners favor lower RPM's because they have a lower resonant frequency, and the smaller diameter helps increase the air velocity."
formulas in here , length vs dia.
Intake Manifold Tech: Runner Size Calculations - Team Integra Forums - Team Integra
Acoustic Supercharging in application 18v883 TypeIII : MGB & GT Forum : MG Experience Forums : The MG Experience
ScienceDirect.com - Applied Acoustics - Acoustic vibrations in intake manifold system and the supercharging of engines
The Following User Says Thank You to MGB=MPG For This Useful Post:
ECONORAM (06-29-2012)
Old 06-28-2012, 07:36 PM   #10 (permalink)
darcane's Avatar
Modern airboxes make use of resonance to further assist filling the combustion chambers with air. Altering the size of the airbox and related tubing will affect the frequency it resonates at.
I'm not real familiar with your particular Civic, but a lot of modern airboxes I've seen have what's called a Helmholtz resonator on it, which helps to reduce noise and improve airflow at specific RPMs.
I don't have specifics on how you are supposed to size the airbox and/or Helmholtz resonator, so I can't help you there. I will need to build one for my race car project though, so it's something I need to get more info on.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
