Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 10-15-2018, 10:17 PM   #1 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Error disconnecting battery hardware
While taking apart the hardware that connects my bikes 42 volt lithium battery, I made a mistake that allowed the live positive and negative wires directly connected to the battery to touch momentarily two or three times. I stupidly almost shocked myself. I didn't notice how the lines could still touch. It blackened parts of a bolt, cut a small thin washer, and made sparks.
Did I just ruin my battery?
ID:	25017   Click image for larger version
Old 10-16-2018, 04:45 AM   #2 (permalink)
It's likely still fine looks like the insulation on the wires didn't even get close to melting. Lithium ion batteries are fairly tough. If it's a LiFePO4 it's really tough, until it gets cold.
Old 10-16-2018, 09:56 AM   #3 (permalink)
Yeah, I'd say you're probably still fine. Heat is a battery's enemy. Looks like all the heat went into your connectors.
