Old 03-12-2011, 11:28 AM   #1 (permalink)
new to the forum
Not exactly new, but been a long time lurker. This forum says I need 10 posts to be able to send private messages.. This is number 6.
I am active on several other forums as well.
GTD Diesel, GTD VW Diesel - Index
Biodiesel infopop, Forums
I own a 1980 rabbit diesel. I am trying to get the highest mpg as possible, without adding a boat tail, because I pull a trailer behind the car moving stuff around very often.
My goal is to get into ~60mpg area.
Old 03-12-2011, 03:12 PM   #2 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder.com .
What fuel mileage are you getting now ?
60mpg is what many would like to get
Old 03-12-2011, 06:37 PM   #3 (permalink)
I have a 1.5L diesel, I get 38mpg around town and highway. I got 32mpg pulling a trailer with a motorcycle on it at 65mph in 30*F
The 1.5L is pretty well worn out. By manufacturer specifications it is no longer a serviceable engine and needs replacement. mfg wear limit for compression 398psi or 40psi difference between cylinders.
I am at 310, 350, 370, 370.
I have a 1.9TD from a 95 jetta going in it this summer. Just making sure its bottom end is nice and tight so it can provide me some good service.
Old 03-13-2011, 03:23 PM   #4 (permalink)
euromodder's Avatar
After 30 years and probably a good many miles, it's hardly surprising for one of the first faster-revving diesels.
The 55 kW / 75HP TD or a 90 HP TDi ?
The TDI would be overkill for the light Rabbit
Good luck with re-engining it !
Old 03-13-2011, 03:27 PM   #5 (permalink)
the 75HP IDI motor
Old 03-14-2011, 01:26 PM   #6 (permalink)
90 day: 51.82 mpg (US)
That said, your trailer hitch would be a good mount point for a lightweight boat tail for the times you're not towing.
Adding a hitch to my Firefly is on the to do list for that reason (and also so I can occasionally tow a light trailer).
