Old 06-26-2008, 01:22 PM   #1 (permalink)
Gasoline Hater
The Baron's Avatar
Blue Bimmer - '87 BMW 535 i
Stella's Ride - '03 Mini Cooper
90 day: 34.97 mpg (US)
RR's Raven - '05 Yamaha R1
Is Ethanol Robbing Me Of MPG?
As you may know, the Commonwealth of Virginia mandates 10% ethanol in every station's fuel tanks.
I've been told this costs us about 10% on efficiency.
What do the experts here say?
Converted Skeptic
Old 06-26-2008, 01:30 PM   #2 (permalink)
Harebrained Idea Skeptic
The White Car - '84 Mercedes-Benz 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 BMW 535i
Last 3: 23.86 mpg (US)
Yes. Ethanol provides less energy per unit volume, and the A/F ratios are not the same, so more ethanol is consumed.
This has been known since carburetor days when larger jets had to be used when running ethanol.
Old 06-26-2008, 01:35 PM   #3 (permalink)
Gasoline Hater
The Baron's Avatar
Bollocks!
Is it harder on an engine that isn't a "FlexFuel" vehicle? I'm pretty sure the German engineers who designed my car in the 1980's didn't do so with 10% ethanol in mind.
Converted Skeptic
Old 06-26-2008, 02:01 PM   #4 (permalink)
It'll make it run a bit leaner, but probably not 10% leaner, as the ECU has adjustment available. I don't think 10% counts as "flex fuel" anyhow.
Old 06-26-2008, 02:05 PM   #5 (permalink)
10% seems like a bit much. I loose about 2 mpg or so on the Matrix when using E10. They do this because ethanol burns cleaner than gasoline.
Old 06-26-2008, 02:12 PM   #6 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Comparing the energy content of ethanol and gas, E10 has 3.2% less energy per gallon. It raises the octane, though, so, as always, YMMV. Studies have shown reductions in the 2-3% range.
Old 06-26-2008, 02:16 PM   #7 (permalink)
Higher octane than necessary reduces efficiency, as the burn is cooler. Increased octane is of no benefit if there is no pinging/detonation or the ignition can't be advanced to take advantage of it.
Old 06-26-2008, 02:23 PM   #8 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
While this is true, I think it's fair to say 87 octane e10 is 87 octane in the same was the 87 octane non-ethanol gas was 87 octane before the ethanol mandates.
Old 06-26-2008, 02:24 PM   #9 (permalink)
Hello,
I believe that ethanol adds some necessary oxygen to the mix, so it burns cleaner. Whatever the reason, it is there -- something has to replace the MBTE since that crap was/is messing up the groundwater.
Old 06-26-2008, 02:40 PM   #10 (permalink)
Hypermiler
Wagons
Interesting to note, MTBE has about 80% the energy of gas, while ethanol has about 67%. So moving from an MTBE mix to ethanol is about the same drop as moving from straight gas to MTBE.
http://www.epa.gov/otaq/regs/fuels/ostp-3.pdf
As can be seen in Table 3-1, the theoretically expected decrease in fuel energy as a result of oxygenate use is in the 2% to 3% range when compared to gasoline. This corresponds to 0.5 to 0.8 miles per gallon for a car that averages 27 miles per gallon. As can be seen from the works cited below, research in this area indicates that any fuel economy loss experienced as a result of oxygenate use agrees with the theoretical prediction for fuel energy loss. Thus, it is reasonable to conclude that any fuel economy loss experienced with oxygenate use is solely a function of the change in fuel composition and the resulting slight decrease in energy content of the fuel.
http://tonto.eia.doe.gov/oog/info/twip/twip.asp
MTBE and ethanol contain about 80 percent and 67 percent, respectively, of the energy in conventional petroleum-based gasoline. The result is that typical oxygenate blending reduces the Btu content of gasoline by two to three percent.
[Article] Better Fuel Economy with Ethanol? SVOboy General Efficiency Discussion 62 04-02-2010 11:31 AM
Poll: MPG before and after hypermiling peterj Hypermiling / EcoDriver's Ed 36 04-23-2009 06:16 PM
Ethanol kills grain food market WaxyChicken The Lounge 14 12-11-2008 10:07 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
School teams to compete in cross country MPG Challenge - Possible $1,000,000 prize ericbecky EcoModding Central 9 03-22-2008 09:15 PM
