Old 08-21-2010, 11:26 PM   #11 (permalink)
Originally Posted by 320touring View Post
As for the USA-do the laws on emissions vary in every state? Are diesels more acceptable in some states than others?
Yes and no. IIRC, standards for new vehicles are pretty much uniform, except for California. That's why you sometimes see mention of a car being a California or Federal/49-state model.
What varies are emission checks on vehicles. This varies not only by state, but by county/city within states. For instance, here in Nevada an annual smog inspection is required only if you live in the two (or maybe three) counties with substantial urban areas, but not in the rural counties.
Just FYI on diesel, happened to notice prices as I passed a local station today. Regular $3.19/gal, diesel $3.09. And saw a diesel pickup pulling out, ahead of a dense cloud of black smoke...
Old 08-22-2010, 10:47 PM   #12 (permalink)
90 day: 29.78 mpg (US)
States do have varying emissions standards, with CA being the most stringent. Unfortunately (or fortunately depending on how you look at it), CARB rules often affect the other states because a manufacturer doesn't want to build multiple versions of a power train.
I believe CARB is the reason diesel is not extensively used in the US.
Old 08-23-2010, 07:48 AM   #13 (permalink)
Chug - '96 Volkswagon Polo CL
90 day: 49.42 mpg (US)
L'Autre - '03 Renault Megane Sport Tourer Expression
Diesel
90 day: 45.02 mpg (US)
My little '96 polo diesel with no particle filter and only and early and probably dead Cat gives out no stir whatsoever.
i know this sounds odd and alil like a conspiracy theorey, but do you thing Big oil have got the manufacturers in the states to make the Diesels there clanky and smokey???
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 08-23-2010, 08:57 AM   #14 (permalink)
No nickname - '17 Chevrolet BoltEV Premiere
We were shown by GM how great diesels were in the late 70's when they converted gas burners to diesel. They had a small problem breaking crankshafts and such. Really gave diesels a bad reputation. Then jokes about sounding like a garbage truck.
I believe emissions has something to do with it now. That's why in the last year or so, the US has gone to an ultra-low sulfur diesel formula. It may make it easier to certify a diesel emissions legal now.
Old 08-23-2010, 01:36 PM   #15 (permalink)
No.
There are almost no manufacturers of diesel cars in the States. VW was the only one with a diesel passenger vehicle for many years, and the motor was very quiet and efficient.
Big Oil doesn't care if they sell diesel or gasoline, as they are all petroleum products.
Precisely. Ultra Low Sulfur Diesel (ULSD, 15ppm) has replaced Low Sulfer Diesel (LSD, 500ppm) by law. This change was needed for catalytic converters to be used on diesel engines.
The downside of the sulfur removal process is a slight drop in fuel lubricity and power (~1%). This means that diesel today returns about 1% less MPG than diesel prior to 2007.
We will begin to see more diesel engines in the US, but it will take some time. I'm dreaming of a Toyota Tacoma turbo diesel.
Old 08-23-2010, 08:09 PM   #16 (permalink)
Not Catalytic converts but Diesel Particulate Filters (DPF) require ULSD.
Old 08-23-2010, 08:27 PM   #17 (permalink)
To the best of my research, both catalytic converters and particulate traps require ULSD. Urea reagents are often used in place of catalytic converters however.
Old 08-24-2010, 07:14 AM   #18 (permalink)
Diesel
[QUOTE=redpoint5;190265]
The downside of the sulfur removal process is a slight drop in fuel lubricity and power (~1%). This means that diesel today returns about 1% less MPG than diesel prior to 2007.QUOTE]
Reaally? well flip my hat I didn't know that!
Old 08-24-2010, 09:21 AM   #19 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Just for reference
From New automotive emissions standards
Old 08-24-2010, 09:35 AM   #20 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
so whats the script with engine importing into the US?
I take it you can import engine types that were already for sale in the US? E.g the honda leanburn..
Seems a shame if you cant take advantage of more economical engines.
As for big oil-they probably do prefer petrol as you use more volume for the same distance..
Getting European mpg ratings? Daox General Efficiency Discussion 2 07-16-2010 02:36 PM
Will ScanGauge (or any other MPG display) work on European 2003 Ford Focus diesel? MetroMPG Instrumentation 7 01-09-2010 01:14 PM
Article: "Daily-Driver Challenge: Hybrids, Diesels...and a Smart ForTwo" 1337 General Efficiency Discussion 0 09-08-2009 03:44 PM
Reprogramming US ECU maps on 3.8 Buick with european, possible? rmay635703 EcoModding Central 0 06-18-2009 12:38 PM
(long) Scangauge II vs. old European diesel Renault groar Instrumentation 0 08-13-2008 05:40 PM
