Old 08-24-2010, 10:07 AM   #21 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Originally Posted by 320touring View Post
so whats the script with engine importing into the US?
I take it you can import engine types that were already for sale in the US? E.g the honda leanburn..
I guess you can import just about anything, as long as it passes emissions tests.
Old 08-24-2010, 07:27 PM   #22 (permalink)
To the best of my research, both catalytic converters and particulate traps require ULSD. Urea reagents are often used in place of catalytic converters however.
Cats were used before summer 2006 when ULSD was phased in so no it is not required for cats. Urea is used to control NOx emissions which a diesel cat can not control because the diesels run lean unlike a gas engine. Diesel cats only control CO & HC, the DPFs go after soot or PM.
Old 08-24-2010, 09:18 PM   #23 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
How is it that VW's tdi had a cat before ULSD was common and available then?
Getting European mpg ratings? Daox General Efficiency Discussion 2 07-16-2010 02:36 PM
Will ScanGauge (or any other MPG display) work on European 2003 Ford Focus diesel? MetroMPG Instrumentation 7 01-09-2010 01:14 PM
Article: "Daily-Driver Challenge: Hybrids, Diesels...and a Smart ForTwo" 1337 General Efficiency Discussion 0 09-08-2009 03:44 PM
Reprogramming US ECU maps on 3.8 Buick with european, possible? rmay635703 EcoModding Central 0 06-18-2009 12:38 PM
(long) Scangauge II vs. old European diesel Renault groar Instrumentation 0 08-13-2008 05:40 PM
