Old 09-04-2008, 10:54 PM   #1 (permalink)
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Geo Metro Xfi
90 day: 51.06 mpg (US)
EV motor question?
I have been reading Ben and Pauls EV build threads. Noticed both of you guys used lovejoy's on yours, Why? I was thinking of when I would do mine mount motor a little above tranny and chain and sprocket it. That way getting more end clearance and allowing battery room below motor. Do you guys think this would work? I realize I would have to build new supports for engine/tranny, but would not be a huge issue.
Old 09-04-2008, 11:22 PM   #2 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
tranny bearings are not designed for that kind of load, a chain is going to pull on the shaft from the side.
Old 09-04-2008, 11:33 PM   #3 (permalink)
EV test pilot
bennelson's Avatar
Electric Cycle - '81 Kawasaki KZ440
90 day: 334.6 mpg (US)
S10 - '95 Chevy S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 Ben Nelson's "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Toyota Prius
90 day: 78.16 mpg (US)
Mounting with a chain and sprocket works fine. Ryland is right about direction of forces though. Maybe an additional bearing and support could be added to take care of that?
I don't have room in the Metro for the motor ABOVE the tranny.
Here is an electric trike done in a way similar to what you are thinking.
The electric motor sits above a Chevy S10 rear axle spun around backwards. Both the motor and axle have sprockets on them, and there is a chain wrapped around connecting the two.
Lots of different ways to connect a motor and transmission together. I went with the Lovejoys because it seemed pretty simple. Plus, that's what the Forkenswift is using, and I am "borrowing" a lot of ideas from that project.
Check out Shifty's EV car build for another type of coupler.
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
Old 09-05-2008, 12:08 AM   #4 (permalink)
Addicted
bbjsw10's Avatar
Ryland, thanks I was wondering about that. It got me thinking what about a snowmobile clutch instead of transmission. May not work on a car but a trike, Possible? It would allow low gearing for take off and as RPM's increase so would gear ratio. Or maybe I had a brain fart, who knows.
Old 09-05-2008, 12:18 AM   #5 (permalink)
PaulH
MPaulHolmes's Avatar
I chose lovejoys because I knew I was going to not be even close to 0.003 inch of center between motor and transmission shaft. With the rubber spider in the middle, it allows for a fair amount of wiggle and sloppiness. It's designed for pumps on farms or whatever, where some farmer is sort of slopping something together. haha! No offense to any farmers out there.
kits and boards
EV Driver here just joined up EVDRVR Introductions 26 09-14-2008 03:28 PM
Riley's EV conversion WannabeEVer Fossil Fuel Free 3 06-28-2008 01:47 PM
Apparent yearly EV meet @ DVC in Concord CA Red General Efficiency Discussion 1 04-28-2008 09:50 AM
What kind of EV would it take? SVOboy Fossil Fuel Free 40 01-22-2008 08:02 PM
Practical? Possible? Taurus EV Conversion WaxyChicken Fossil Fuel Free 30 01-18-2008 12:12 AM
