Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 05-18-2012, 11:50 PM   #11 (permalink)
Or you are brain washed by the government because the hho works and lets see 100 ft of vacume line making the engine work harder take it of at the tb and that is less vCard you have to make. All the evap does is collect vapors bif whoop
Old 05-18-2012, 11:51 PM   #12 (permalink)
And BTW the government and EPA don't care bot you or three environment
Old 05-19-2012, 10:55 AM   #13 (permalink)
Did you blank off or just disconnect the evap?
Im interested in seeing your data, as from your other post, your CAI reduced your fuel consumption roughly by a 1/2 and disconnecting the evap reduced it by another 1/3. Which in total, is a 2/3 reduction of your original fuel consumption from these mods.
*calculated from the 10-11mpg with CAI stated in your post, 5-6mpg before CAI fitted and now 15-16mpg with a disconnected evap.
Please note, I have not been "brain washed by the government" and as such I am somewhat sceptical of your claims, which are not backed up.
Old 05-19-2012, 11:26 AM   #14 (permalink)
No I was getting 12 ish. Put 33s on the truck
So out went down too ten.then the cai got me back to ten.then then the. Superchip tuner to 11. Then my intake blew out so I was down too 5 ish. Now with new 02 sensors and no evap I'm getting 16. And am now done with this site and the people on it.
Old 05-19-2012, 12:09 PM   #15 (permalink)
Oh by the way why don't y you go take your evap of at your tb block it off there and see what it does cars from the beginning of cars to 96 didn't care bout evap
Old 05-19-2012, 12:20 PM   #16 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
could just disconnect your purge valve's electrical connector, assuming the purge valve isnt leaking, this should accomplish the same thing. and possibly isolate the change from other vacuum lines, or changes in un metered air entering your engine.
Old 05-19-2012, 12:27 PM   #17 (permalink)
Team Saturn
cars long before 96 had evap systems. might not have consisted of much more than a gas cap, the canister, and a vacuum line hooked up to ported vacuum on a carburetor, but they had evap systems
since 1971 according to wki
Old 05-19-2012, 12:48 PM   #18 (permalink)
Huh by disconnecting it at the tb you eliminate all the vac lines I capped it off there
Old 05-19-2012, 08:33 PM   #19 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
i have two questions for you sir;
1;why should we prove what your saying is true(most modern evap systems only work on start up; to produce easier start up; the gas vapors come from the tank)
and 2; you put 33's on your truck did you change the speedo gear/sensor(because i doubt they are stock for your truck; and it's more then likely why your truck is not telling you the right distance you've traveled)
ps. most of your posts are in the unicorn corral.
Old 05-19-2012, 08:36 PM   #20 (permalink)
No evap is on all the time and I changed the Speedo for bigger tires and their stock ones and its you don't want to test it then shut up
