Old 11-28-2010, 11:12 PM   #31 (permalink)
http://www.innas.com/Assets/files/Hydrid%20brochure.pdf
When you build a vehicle with a system similar to this, you will see addtional improvements acheived by every other known method of reducing the watts per mile cost of moving from point a to point b.
Every incremental improvement will be automatically maximised by the self compensating smart powertrain system.
Every time you reduce the total watts per mile of energy required it will translate directly into better Miles Per whatever energy unit you are consuming.
Even a fresh wax job.
regards
Mech
Old 04-21-2011, 11:15 PM   #32 (permalink)
99CleanEM1
Originally Posted by RobertSmalls View Post
You should start a thread on how you were able to improve the efficiency of the already economical Civic.
You already mentioned you had a 4" exhaust on your Civic, which I'm sure went along with a similarly up-sized intake and different cams. How did you minimize the negative FE impact of those modifications?
I dont think I come here enough to benifit from a whole thread for me.... Stock pistons can only handle so much so with forged ones at part throttle tuning you can tune very lean similair to the already produced "lean burn" engines.
I did add a better flowing intake manifold and considerably bigger cams... but from variable valve timing which we are all familiar with it doesnt take place until higher in the rpm band where the boost builds but isnt always necessary. Hondas are truley amazing to me and seemed way ahead of their time in terms of technology for multiple applications and longevity
Old 04-21-2011, 11:27 PM   #33 (permalink)
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Originally Posted by tasdrouille View Post
We have changed everything on our way, but we have not been able to change ourselves. Not yet.
those that are quick to change things are themselves unable to adjust to change.
Super MPGuino? gtkid2002 OpenGauge / MPGuino FE computer 97 02-06-2011 12:39 PM
Long time modder, 1st time poster :) JohnnyGrey Introductions 8 04-29-2008 06:38 PM
Opengauge/MPGuino development: Freeduino signal processing dcb OpenGauge / MPGuino FE computer 6 04-16-2008 09:40 AM
Long time GS/Ecomodder lurker LostCause Introductions 6 02-24-2008 08:52 PM
Why my gas mileage sucks. Big time. Peakster The Lounge 4 01-01-2008 04:38 AM
