OK, there are plenty of cars that are like that already, and if anything adapt the technology to something simple at first then scale up. If you look at the Forkenswift and some of the other budget electric cars that have been built here, they can act as a guide to doing the electric part on a budget. Paul and Sabrina's budget open source controller is here also, plus there are a lot of used controllers that can be used as a base for bigger project.
You have to build something if you want to get buzz. You don't know how to weld and fabricate, it's about time that you did if you want to keep your costs down. The less that you farm out, the better control you have over the design.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
