Old 08-25-2010, 11:13 PM   #201 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
I know it's been a little while since the last post. Just wondering if anyone considered the Tesla Turbines. From what I understand they are a series of disks that you jet steam at the edge. Sounds relatively simple to make.
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 08-25-2010, 11:54 PM   #202 (permalink)
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Subaru Impreza Outback Sport
90 day: 27.81 mpg (US)
yup, that's been brought up. It still seems like the best second choice to me, the first being a old pneumatic tool's turbine (due to ease of construction).
Redneck Repair forum
Old 08-26-2010, 12:55 AM   #203 (permalink)
Cool. Kinda skimmed over the thread again, so I guess I missed that post.
Old 08-26-2010, 07:30 AM   #204 (permalink)
The idea hasn't lost steam (har har). I still want to make one. I do actually think that the tesla turbine would be easier to make, but neither are going to be easy. I have found bearings capable of handling the higher rpms that the turbine may see. I just need to find a way to make a shaft and spacers that can handle high rpm.
Old 08-26-2010, 12:11 PM   #205 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
In Tesla's day Tesla turbines held were marginally better than competing turbine designs in the application for commercial electrical production. Using them for other applications one must keep in mind Tesla turbines have a few fundamental flaws. They don't respond well to input variations as well as variations in load. As a load is applied to them their efficiency plummets rather quickly as the load increases. They also don't handle high temperatures well as the discs start to warp.
That said for a homemade low temperature steam turbine they may be the easiest solution. On a car they just won't be very efficient.
Old 08-26-2010, 12:22 PM   #206 (permalink)
Do conventional turbines handle variations in load better? I would tend to think not.
Old 08-26-2010, 12:29 PM   #207 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
Go to a local computer repair shop and ask for some dead hard drives to make the tesla turbine. See Build a 15,000 rpm Tesla Turbine using hard drive platters
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 08-26-2010, 12:44 PM   #208 (permalink)
You still need to make a custom shaft to hold the disks.
Old 08-26-2010, 01:22 PM   #209 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
The motor itself will hold them, you just need to attach the motor to something. Unfortunately, I don't think HDD motors will actually generate anything, so that poses another issue.
As someone mentioned before, the Tesla Turbine's efficiency drops severely as it gets loaded down. Since it relies on the surface tension of flowing fluid to power it, instead of mechanical force (yes, I know, surface tension is a mechanical force), it doesn't respond well to changes in either input or output.
This is why I never mentioned it, even though they're one of my favorite study subjects.
Old 08-26-2010, 03:03 PM   #210 (permalink)
DieselMiser
ConnClark's Avatar
Yes they do. Conventional turbines operate on the defection of mass. A Tesla turbine relies on cohesion of the air sticking to the rotors. A sudden change in supply flow or load breaks this cohesion and generates turbulence that drops its efficiency.
The Following User Says Thank You to ConnClark For This Useful Post:
Daox (08-26-2010)
Mimicking Gen3 Prius Exhaust Heat Recovery Daox EcoModding Central 77 08-01-2018 04:16 PM
Power and Heat considerations (enclosures, etc) dcb OpenGauge / MPGuino FE computer 22 03-31-2011 08:59 PM
High efficiency ICE (exhaust heat recovery) amnonholland EcoModding Central 21 06-27-2010 01:00 AM
Waste Heat from Exhaust TES111 EcoModding Central 35 11-21-2008 12:31 PM
Steam engine (from exhaust heat) iHero General Efficiency Discussion 23 09-08-2008 12:30 AM
