Old 05-23-2008, 01:36 PM   #41 (permalink)
Impatient Driver
chrislk1986's Avatar
98CivicHX - '98 Honda Civic HX
90 day: 40.02 mpg (US)
Are you going to be leaving the front bumper on?
Old 05-26-2008, 07:51 PM   #42 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
well after 2 days of working on the front end its in near final order.. I got to one point and had to remind myself this was for MPG not good looks and needed to spare the detail sanding and such till a later date so I can get this thing on the road... just need to get some thin flexible clear plastic from the glass place that will cover the head light holes.. and you can see the LED DOT approved blinker lights in the corners of the headlights, this area is not used by the light spread.. so instead of sinking them in the new nose I just put them there..
Here are the results..
It made noticeable improvements, even with out the headlight holes covered.. the throttle was no ware near where it was with out the nose and coasting down the hill near out place was a faster speed that previously.
after the headlight covers i need to make a bottom removable pan for it and figure out where tio let air in to cool the engine.. the nose did make my temp gauge rise a bit.. even with the headlight holes and the bottom open.. so it surly deflecting air around the car even as is..
Old 05-26-2008, 07:55 PM   #43 (permalink)
Veggiedynamics
Yeah the front bumper is still there, everything is built around the stock bumper.. if i get in a crash the new nose is going to bust up its simply strong enough to keep the wind at bay.. the bumper is still there for crash protection..
Old 05-26-2008, 08:40 PM   #44 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Paint the whole car in grey primer now and it will be sweet.
GeoMetroforum.com - got mpg?
Old 05-26-2008, 08:42 PM   #45 (permalink)
Veggiedynamics
Yeah with as much works as ill be doing year.. or was thinking black .. flat blackk.. stealthy
Old 05-26-2008, 09:31 PM   #46 (permalink)
Blue - '77 Chevy P/U
paint it with Rustoilum ,,white ,less a/c
Old 05-26-2008, 11:16 PM   #47 (permalink)
Veggiedynamics
Less AC?? there is no AC in a CRX HF.
Yeah white would make sence to lessane solar gain.. however it will get primer gray for now till the thing is done then ill make it look pretty..
Function over form in my book.
Old 05-26-2008, 11:42 PM   #48 (permalink)
Veggiedynamics
Also if you didn't notice in the photos.. no exterior mirrors
Old 05-28-2008, 09:11 PM   #49 (permalink)
Veggiedynamics
Well head light covers are on.. .. worst part now is the cooling fan is running to cool it off while driving .. tis will be fixed by lowering the small stock air dam directing more air from under the nose up into the radiator. also i might experiment with raising the back of the hood to draw air through the engine compartment.. however I don't know if thats aerodynamic suicide..lol
Old 05-28-2008, 10:05 PM   #50 (permalink)
Veggiedynamics
Here are the photos with the light covers in place:
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1056 12-14-2024 12:21 AM
crx hf help need more info, rear wheel skirts RP-CLMBR Aerodynamics 2 07-16-2008 09:24 PM
Repping the old school Hondas - 85 CRX HF 1GCRXHF Introductions 4 06-16-2008 01:14 PM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 04:14 PM
AFS Trinity EXTREME Hybrids!!! cfg83 General Efficiency Discussion 10 01-18-2008 07:15 PM
