Old 03-30-2009, 03:31 AM   #11 (permalink)
Lowering a car is a lot of work and money for reducing frontal area from tires by a few square inches. Plus the ground effect increases... the effect of which would depend on the individual car.
Old 03-30-2009, 11:50 PM   #12 (permalink)
EcoMod Wannabe
Sean T.'s Avatar
Taurusaurus Rex - '97 Ford Taurus GL (Sedan)
90 day: 19.39 mpg (US)
Blue Wagon - '00 Ford Taurus Wagon SE Comfort
90 day: 19.61 mpg (US)
I have the same problem. My bumpers curve in and so it's not easy to build a wheel well cover that goes down very far...
Old 04-01-2009, 10:15 AM   #13 (permalink)
Weight Reduction
Drive Stick's Avatar
Celica GTS - '02 Toyota Celica GT-S
90 day: 36.32 mpg (US)
Send a message via AIM to Drive Stick
Is the picture of your taurus legit, or is that a photoshopped bumper cover? That's about what I'd need to make, in order to cover my front end.
Old 04-01-2009, 12:33 PM   #14 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
it seems that on recent cars the bumpers have gotten a little wider down low, but most still leave a little bit of the tire side exposed neat the bottom end.
one car wich has an interesting feature and some pictures on this area is the tesla roadster...
in the first pic there's a virtual model wich shows the airspeed accross the tire edge
in the second pictures there a mock up wich has "reverse mudflaps" taped to cover this area, and when you look carfully the production model seems to have retained this feature
now this could very well be a stability air rather than drag reduction, but a similar setup might benefit existing cars with the same configuration...
Old 04-01-2009, 01:15 PM   #15 (permalink)
90 day: 57.73 mpg (US)
Those Tesla deflectors are likely there for drag reduction, and something similar on the Neon may help slightly.
I can post a similar before/after CFD image of a bumper which leaves some of the tire tread (face) exposed vs. one which doesn't. I'll see if I can find it...
Old 04-01-2009, 01:25 PM   #16 (permalink)
Weight Reduction
That would be great, because I have no idea where you guys are finding these images.. I'm just getting into all of this, and the aero mods are my next things to do so the more I learn the better mods I can make.
Old 04-03-2009, 09:07 AM   #17 (permalink)
Source: Contribution of different devices to the total drag - http://www.dd.chalmers.se/~lelo/rvad...on-to-drag.pdf
Old 04-03-2009, 10:53 AM   #18 (permalink)
this moddification was accepted by the styling department
that explains a lot...
Old 04-03-2009, 12:41 PM   #19 (permalink)
tasdrouille's Avatar
The Guzzler - '08 Hyundai Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '11 Kia Soul 2U
The SAE paper on the development of the c6 z06 corvette calls them wheel openings extensions. They were added to reduce drag.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 04-03-2009, 03:28 PM   #20 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
MetroMPG -
This is really cool. I only have frontal mudflaps installed right now, but I also have some "shaped" mudflaps in the garage that I could adapt for this use.
CarloSW2
American Solar Energy Society
Cheap-o Smooth Wheel Covers bennelson Aerodynamics 40 03-16-2009 12:55 AM
Rear wheel skirt / cover question pasadena_commut Aerodynamics 5 02-16-2009 05:50 AM
wheel covers: corugated plastic or taped hubcaps? modmonster Aerodynamics 4 02-08-2009 08:54 PM
Fender flares to make front wheel skirt jthistle Aerodynamics 13 09-12-2008 11:16 PM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 09:43 PM
