Old 01-14-2015, 08:55 PM   #1 (permalink)
Ford XLT Naked - '14 Ford F-150 XLT
90 day: 15.04 mpg (US)
Ford G-4 with Stinger - '14 Ford F-150 4X4 Super Crew XLT
90 day: 19.8 mpg (US)
Ford Stealth G-4 - '14 Ford F-150 4X4 Super Crew XLT
90 day: 16.16 mpg (US)
XLT Towing Keystone 5th wheel trailer - '14 Ford Keystone 5th Wheel XLT
90 day: 9.03 mpg (US)
Trip 2015 C Max Energi - '15 Ford C Max Energi SWP
90 day: 38.2 mpg (US)
Local 120 volt 2015 C-Max Energi - '15 Ford C-Max Energy SEL
90 day: 55.65 mpg (US)
Local 240 volt 2015 C-Max Energi - '15 Ford C Max Energi SLE
90 day: 57.63 mpg (US)
Energi Combined - '15 C Max Energi Leather
90 day: 51.2 mpg (US)
MoonDust for Travel - '19 Chevrolet Bolt LT
90 day: 123.11 mpg (US)
MoonDust 3 with 90% CE - '19 Chevy Bolt LT
90 day: 127.57 mpg (US)
Ecopia IV - '19 Chevy Bolt Lt
90 day: 126.39 mpg (US)
Ecopia IV Trip Log - '19 Chevy Bolt LT
90 day: 121.01 mpg (US)
Rate Rider Chevy Bolt - '19 Chevrolet Bolt LT-2
90 day: 123.16 mpg (US)
Teal Force One 70% - '24 Hyundai Ioniq 5 SEL
90 day: 98.52 mpg (US)
Teal Force Two 90% - '24 Hyundai Ioniq 5 SEL
90 day: 113.62 mpg (US)
Road Horse Power
Earlier I posted my HP table and the formatting was all screwed up in the process. The relevant data from my HP posting is for the 80 MPH and 85 MPH data which I will now summarize.
At 80 MPH the truck naked gets 15.1 MPG which translates to 64.2 RHP.
At 80 MPH with aero appliances 18.2 MPG which translates to 53.3 RHP.
This means it took 10.9 less HP to do 80 MPH with the aero appliances added.
At 85 MPH the truck naked gets 13.2 MPG which translates to 78.1 RHP.
At 85 MPH with aero appliances 16.2 MPG which translates to 63.6 RHP.
This means it took 14.5 less HP to do 85 MPH with the aero appliances added.
The truck naked requires 53.5 HP to do 75 MPH v 53.3 HP to do 80 MPH/aero.
The truck naked requires 64.2 HP to do 80 MPH v 63.6 HP to 85 MPH/aero.
This is an 17% and a 18% improvement at speeds respectively with aero.
The Following 4 Users Say Thank You to aerostealth For This Useful Post:
aerohead (01-15-2015), BabyDiesel (04-07-2015), BamZipPow (01-15-2015), mikeyjd (04-07-2015)
Old 01-15-2015, 03:18 AM   #2 (permalink)
Volvo-driving MachYeen
Fingie's Avatar
Neo Volvo - '98 Volvo S70 10V
90 day: 24.98 mpg (US)
Soo technically you could also have a higher top speed? Isn't it that aerodynamics dictate top speed
If you don't make any mistakes in your life,
life itself will be a f*ckup.
With Volvo to Valhalla and back!
Old 01-15-2015, 08:42 AM   #3 (permalink)
High Speed Testing
Yes, my truck would have a higher top end speed. Aerodynamics is free HP. Phil Knox and I beleive that my F-150 should have a top end of around 150 MPH. Ford set a record of 148 MPH with a Raptor using 412 HP and my truck can produce 365 HP at 5000 RPM. At these speed regimes my aero should be worth 60 free HP. Such a test would require speed rated tires, and lubricant. It would not hurt to have a spare truck in case you blew yours up. That's where the deeper pockets Ford has is of critical importance. My aero needs improvements such as a belly pan, and boat tail extention but we beleive it could do it. In Texas there is a stretch of turnpike where the posted limit is 85 MPH and we could easily test 90 MPH out. A 100 MPH test would be nice to start forming a good graph curve. We think the engine would be in a very efficient place at 120 MPH but my current tires and limiter would not allow me to reach that speed. P.S. At 85 MPH my RPMs were 2,050.
The Following User Says Thank You to aerostealth For This Useful Post:
Old 01-15-2015, 12:34 PM   #4 (permalink)
I assume you are using a BSFC number to go from MPG to HP? You mentioned some numbers in your other thread that makes me think that. What are you using for the MPG (and/or fuel flow)? Just the truck's data via the OBDII port?
Are you using a single number for BSFC? Or do you have a map?
It's a useful way to think about the numbers no matter how you did it. Really shows what the aero is worth.
Old 01-15-2015, 01:25 PM   #5 (permalink)
If your gearing is tall enough so that you could reach the higher speed without redlining the engine, of course.
Old 01-15-2015, 01:32 PM   #6 (permalink)
Bsfc
Yes we are using .452 BSFC per HP hour for the truck. We are assuming gasoline weighs 6.138 lbs per gallon and that our drive line loses are .893. So for the 18.2 MPG at 80 MPH our formula is
80/18.2 = 4.395 x 6.138 = 26.98/.452 = 59.68 x .893 = RHP 53.3
These are useful working assumptions as you say. At 150 MPH the truck would have to get just under 5 MPG to make these numbers work. Phil has data that says these numbers change faster you go. The relationship is not fixed the faster you go. I would have to let him address that.
Old 01-15-2015, 05:22 PM   #7 (permalink)
top speed
Here you can see the relationship between drag reduction,and engine rpm (top speed for any given gearing).
*The streamlining allows engine over-speed and shortened engine life,as well as lower BSFC.
*To get the best mpg,the gearing is altered to get the engine back to it's original BSFC island,which maximizes mpg.
*If our estimates are within range at all,Aerostealth's F-150 might do 156-mph at standard atmosphere.
Old 01-15-2015, 07:13 PM   #8 (permalink)
Thanks Phil. I worked up a graph on really large paper today showing HP on the vertical axis to 425 HP and speed on the horizontal axis up to 155 mph. It looks kind of empty with the data I have only up to 85 mph and 70 HP.
Old 01-17-2015, 03:25 PM   #9 (permalink)
empty
I've got dozens of case files for higher performance cars,some of which can easily exceed 200-mph.Over the coming months we'll be able to reverse-engineer data from their published performance which will help us think about the 'Stealth F-150.'
Here's a higher speed table from HOT ROD Magazine illustrating performance for a car of 25-sq-ft frontal area,at differing Cds.
It gives you an idea of what the F-150 is going to be capable of as its Cd continues to fall.
Old 01-17-2015, 04:06 PM   #10 (permalink)
...beats walking...
Hey, Aerohead, is it possible to get the issue-number/month of that HOT ROD Magazine article where that graph came from?
