Old 02-26-2019, 12:42 AM   #21 (permalink)
...and lower engine compartment temperatures.
________________
Because much of what is in the published literature is nonsense,
and much of what isn’t nonsense is not in the scientific literature.
-- Sabine Hossenfelder
Old 02-26-2019, 10:47 AM   #22 (permalink)
And tend to generally thrash the exhaust system
Old 02-26-2019, 11:23 AM   #23 (permalink)
Jeep - '97 Jeep Cherokee Sport
90 day: 19.36 mpg (US)
Blueberry - '07 Toyota Camry SE
What do you mean by that? It's basically just metal tubing. And the catalytic converter.
Old 02-26-2019, 01:42 PM   #24 (permalink)
..and the moisture that creeps under the wrap and rusts it all.
Hence Ceramic coatings (Inside and out).
________________
Old 02-26-2019, 02:29 PM   #25 (permalink)
I think it would be fine as long as you don't live somewhere where they salt the roads.
Living in Nevada I don't normally think of things like that
Old 02-26-2019, 07:15 PM   #26 (permalink)
Ceramic coating the inside has [anti-corrosion] benefits that wrapping the outside will never have.
________________
Old 02-26-2019, 08:32 PM   #27 (permalink)
That's true. However not all applications come with that option and it is more expensive than wrap.
I'm sure that exhaust paint with wrap would be sufficient to prevent rust (everywhere except the rust belt).
Old 02-27-2019, 11:29 AM   #28 (permalink)
Unless it is a full stainless exhaust with stainless fasteners, wrapping the system generally leads to rust through. Btdt, couple of times including a LA only vehicle. Had one system that fell off the truck intact because the hangers weren't stainless. There is all kinds of corrosive crud being splashed up by the tires even in the desert. If there weren't, the bottom of your vehicle would be clean and rustfree as the day you bought it.
freebeard (02-27-2019)
Old 02-27-2019, 12:21 PM   #29 (permalink)
Makes sense.
...though my vehicle has no rust on the frame or body and minimal rust on the drivetrain and leaf springs. Perhaps I'm an outlier?
Edit: Well actually the exhaust has rust on it too, but it's not rusted through.
Old 02-27-2019, 01:45 PM   #30 (permalink)
How is you handle pronounced?
Just turning the engine on will rust a non-stainless exhaust. From the inside. Even on an air-cooled engine.
________________
