Old 11-11-2010, 01:43 PM   #21 (permalink)
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
I'm not sure if this would work but could you just run 10 8v batteries in a parallel/series setup to give you 40v. I know it would increase the amps but I'm not sure if it would increase the aH.
Or if you would run two strings of 4 12v for 48v and switch to the second string when the batteries are low on the first. This would allow you to also charge one string while using the other.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
Old 11-21-2010, 10:18 PM   #22 (permalink)
Ford Escort 2.0
TomEV's Avatar
Electricar - '89 Ford Escort LX Hatchback
Experiments can support or help disprove theories. In this case it appears that FW may have some positive effect, but the gains are relatively low.
Here are the latest numbers -
Day Miles wH/mi
1 - 11.9 - 224
2 - 13.9 - 217
3 - 11.3 - 232
4 - 23 - 227
5 - 15 - 220
6 - 14.1 - 194
7 - 7.9 - 252
8 - 4.9 - 229
9 - 9.4 - 223
10 - 5.6 - 220
11 - 11.9 - 231
12 - 11.4 - 222
13 - 8.9 - 221
14 - 9.9 - 235
15 - 13 - 242
Average wH/mi with FW on - 226 (FW on during steady state driving)
Average wH/mi with FW off - 229 (from previous months)
So far, the experiment points to the use of FW during certain drive environments as not producing a significant difference. I'd probably need about 30 samples to produce a reliable trend line.
Overall this month, I'm at 229 wH/mi using mixed FW and non FW driving, which is about my normal level of efficiency.
Old 12-02-2010, 10:12 PM   #23 (permalink)
Ford Escort 2.0
TomEV's Avatar
Field Weakening - November's Experiment Draws to a Close
Here are the final numbers -
Day Miles wH/mi
1 - 11.9 - 224
2 - 13.9 - 217
3 - 11.3 - 232
4 - 23 - 227
5 - 15 - 220
6 - 14.1 - 194
7 - 7.9 - 252
8 - 4.9 - 229
9 - 9.4 - 223
10 - 5.6 - 220
11 - 11.9 - 231
12 - 11.4 - 222
13 - 8.9 - 221
14 - 9.9 - 235
15 - 13 - 242
16 - 8.7 - 218
17 - 18 - 235
Overall this month, I used 232 wH/mi using mixed FW and non FW driving, which is about my normal level of efficiency. According to the data, Field Weakening doesn't improve efficiency to a significant degree at mid power levels.
electric car, field weakening
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 05:43 PM
Wake field of pickup KamperBob Aerodynamics 28 07-14-2011 01:52 PM
Fuel Warmer and Fuel magnet? boostanddestroy EcoModding Central 42 04-25-2010 04:48 PM
Deactivating Alternator Field wire Noel DIY / How-to 13 08-28-2008 01:40 PM
Field Weakening Experiment for Speed Increase TomEV Fossil Fuel Free 12 04-10-2008 03:53 PM
