Old 03-08-2011, 09:09 AM   #1 (permalink)
Buggie - '01 Vw Beetle TDI Gls
lots of stops in the country
just wondering, I live about 5 miles from the city and it is all 50 mph limit, and every block along the way has stop signs posted, maybe a 1.5 to 2 miles apart. it's worth getting to 80 to get peak mpg but not sure if it's worth the rush to get there.
If I accelerate slow, I'll get to the next stop before I get up to speed and i dont want ot hammer it to get going, I was going to instal a vacuum gauge and maybe accelerate as fast as the vac gauge dictates. i can only run som many stop signs
any advice?
Old 03-08-2011, 11:17 AM   #2 (permalink)
Smeghead
escort - '99 ford escort sport
90 day: 42.38 mpg (US)
scoobaru - '02 Subaru Forester s
90 day: 28.65 mpg (US)
Instrumentation is a good bet. If you are using a manual Pulse and glide to a stop may be the most efficient fuel wise way to tackle the stop signs. you have to weigh it against increased time to cover the distance and annoyance to other drivers.
Any better route?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 03-08-2011, 12:30 PM   #3 (permalink)
Eco Noob
Doofus McFancypants's Avatar
Red Rover - '01 Nissan Altima GXE
90 day: 30.07 mpg (US)
second the instrumentation.
Once you can see "into" the engine you can figure out the best acel rate that has you gliding to the stop with ease.
depending on how clear you can see the intersections - you may be able to bump start as you coast to the stop to avoid the starter.
Steve - AKA Doofus McFancypants
"If there's a new way, I'll be the first in line - But it better work this time"
First Milestone passed - 30 MPG (city) 5/15/08
Best City Tank - 8/31/09- 34.3 MPG (EPA= 20)
Best Highway Tank - 5/20/09 - 36.5 MPG (EPA= 28)
In effort to drive less:
Miles NOT driven in 2009 = 648 (Work from home and Alt Transporatation)
Old 03-08-2011, 01:41 PM   #4 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
How in the world do you think going 80 mph is going to get you peak mpg? Going 80 probably uses four times the gas you use to go 50.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 03-08-2011, 02:00 PM   #5 (permalink)
No nickname - '17 Chevrolet BoltEV Premiere
If you check his location, you'll note that he's in Canada, so 80 is kilometers, not miles. 80 kilometers per hour equals 50 miles per hour.
Old 03-08-2011, 02:15 PM   #6 (permalink)
Pishtaco
SentraSE-R's Avatar
I figured since he started by discussing the 50 mph speed limit and a 5 mile commute, he would be consistent, so the 80 refers to 80 mph. The other thing is it's no problem to accelerate to 50 mph and coast back down to a stop in 1.5-2 miles. It's not so easy accelerating to 80 and coasting back down within 1.5 miles. Agreed, he could have switched between mph and kph, though.
For a 5 mile drive, I'd bicycle. If I drove it, I'd conserve momentum, and try to reach each stop rolling less than 10 mph if driving a manual, and <20 mph if driving an automatic.
Darrell
Old 03-08-2011, 02:51 PM   #7 (permalink)
That would be Hwy 80 That's a 10-4 good buddy.
Old 03-08-2011, 02:55 PM   #8 (permalink)
Pishtaco
SentraSE-R's Avatar
lol. We should agree on a common language to use on this forum .
Darrell
Old 03-08-2011, 03:38 PM   #9 (permalink)
My bad I meant to use all imperial for ease and I subconsciuosly reverted back to metric
Old 03-08-2011, 04:25 PM   #10 (permalink)
The PRC.
If nobody is behind then pulse as little as you need.
