Old 07-08-2024, 06:46 PM   #31 (permalink)
At what point does the Bowlus Road Chief trailer lose flow attachment?
The separation line will vary by cross-wind conditions. But it's a good point, curve those side panels.
Is speed a factor in max angle?
The general range is 25-250MPH, again depending on conditions.
Originally Posted by JSH
I am surprised that an almost $265K trailer has a cheap looking plywood interior like a budget van build.
The original Bowlus had countertops made from the same aluminum sheet as the shell.
Old 07-08-2024, 07:40 PM   #32 (permalink)
WT with hard left gust
I wonder if the twin-wall polycarbonate's ability to flex enhances flow attachment.
Name:	Screenshot 2024-07-08 at 6.32.18 PM.jpg
Old 07-08-2024, 09:35 PM   #33 (permalink)
Your vehicle's wake is a degenerate form of a Vortex Street.
en.wikipedia.org/wiki/K%C3%A1rm%C3%A1n_vortex_street
Animation of vortex street created by a cylindrical object; the flow on opposite sides of the object is given different colors, showing that the vortices are shed from alternating sides of the object
I would have concerns about buffeting. aerohead would have the most experience with rigid vs flexible structures.
Old 07-09-2024, 06:31 AM   #34 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Is speed a factor in max angle? I always drive 63 mph.
Would you be willing to tuft test it?
Old 07-09-2024, 08:36 AM   #35 (permalink)
Bowlus
I own the Zevo. The Bowlus is just a photo.
The Following User Says Thank You to JohnForde For This Useful Post:
Piwoslaw (07-10-2024)
Old 07-09-2024, 11:14 AM   #36 (permalink)
Apples and oranges. A cube and a tic-tac shape have different aerodynamic characteristics.
A box van is a disaster at the front, with an opportunity for flow reattachment that increases with length, followed by a disaster at the rear.
The Bowlus (neglecting the tow vehicle) has a rounded front and a tapered rear with a variable straight center section. If half the taper at the rear were truncated, the Cd would be maybe 10% higher. Less affected by crosswinds.
Old 07-09-2024, 06:29 PM   #37 (permalink)
plywood & coroplast drawing offering 17, 18.5 & 20 deg
Thinking of cutting the plywood top to initially accommodate all 3
Top will Get a coroplast extension to 48" too
Name:	Screenshot 2024-07-09 at 5.26.19 PM.jpg
Old 07-09-2024, 07:39 PM   #38 (permalink)
This was my suggestion for wire-reinforcing Coroplast (dated 2013!)
From the top, a raw edge, a recessed wire ready for a tape overlay, and a sunken wire that could have the two sides lapped over it and glued or taped. Of course wire can run the length of the flutes for reinforcing in the other direction.
Old 07-10-2024, 10:01 AM   #39 (permalink)
Foam injection works really well, also. Changes the failure point from collapsing the skin between the ribs to the skins which leads to hitting the yield on the outer skin much later in the load process.
Old 07-10-2024, 06:58 PM   #40 (permalink)
4 pics of the Zevo's 'cuff' and gap
ID:	34862   Click image for larger version
ID:	34863   Click image for larger version
ID:	34864   Click image for larger version
Piwoslaw (07-11-2024)
brightdrop, electric van, zevo
