Old 03-13-2018, 09:26 PM   #1 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
2007 Fit?
I’m thinking about Honda Fits as replacement car for my Focus. One that has caught my eye is a blue 07 with 125k miles. It’s an auto-tragic so the wife can drive it. What things should I look out for? Timing belt or chain? Ad says ATF was changed at 100k; is this a normal interval? Any particular areas that are prone to rusting to look out for?
Thanks,
Mike
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
Old 03-14-2018, 04:49 PM   #2 (permalink)
mpg_numbers_guy's Avatar
Toby - '13 Toyota Prius C
90 day: 63.99 mpg (US)
Daz - '15 Mazda 3 iTouring w/ Tech Package
Team Mazda
90 day: 38.2 mpg (US)
The Honda Fit uses a timing chain instead of a timing belt (I believe all Hondas switched to timing chains around 2006).
According to CarComplaints.com, there aren't really any major things to look out for. Honestly from what I found when researching this as a possible vehicle very few complaints were out there. I did find a couple related to power steering failure.
Can't really help with the rusting part since I don't own one; obviously check key areas such as the license plate bolts, wheel wells, fuel tank cap, hood, underbody, etc. A brief Google search didn't seem yield any abnormal results.
2013 Toyota Prius C 2 (my car)
2015 Mazda 3 iTouring Hatchback w/ Tech Package (wife's car)
The Following User Says Thank You to mpg_numbers_guy For This Useful Post:
California98Civic (03-14-2018)
Old 03-14-2018, 10:50 PM   #3 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Glad they went to a chain. Seems more dependable and lower maintainence than the belts.
Old 03-14-2018, 10:58 PM   #4 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
Coil packs.
If the car your looking at has over 120k, they've probably been replaced already.
Also, that little damn clip the sunshade goes into... replaced that twice. Otherwise these little cars are damned bear bulletproof.
The Following 2 Users Say Thank You to samwichse For This Useful Post:
mpg_numbers_guy (03-15-2018), spacemanspif (03-15-2018)
Old 03-15-2018, 12:35 AM   #5 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
Ehem
http://ecomodder.com/forum/showthrea...ick-34756.html
Don't settle for an auto just because someone can't drive it. TEACH THEM!
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following 3 Users Say Thank You to Daschicken For This Useful Post:
Daox (03-15-2018), Fat Charlie (03-15-2018), Gasoline Fumes (03-15-2018)
Old 03-15-2018, 12:37 PM   #6 (permalink)
Spaced out...
Originally Posted by Daschicken View Post
Ehem
I HAVE taught her. She won’t leave the parking lot. Worried about getting stuck if she smokes the clutch, picking the wrong gear if she’s slowing down and the light turns green, blah blah blah. Last time after 20 minutes of parking lot time I said “ok now drive us home” (1/4 miles down a straight road, no lights) and she had a breakdown about pulling into the non-existent traffic....
Good to know the cars are pretty reliable though. Thank you
-Mike
Old 03-15-2018, 12:48 PM   #7 (permalink)
She only does that about using a manual transmission, right?
Old 03-15-2018, 08:46 PM   #8 (permalink)
Spaced out...
Yes lol
She’s very good at stabbing the gas and jumping into traffic....
-Mike
Old 03-15-2018, 10:10 PM   #9 (permalink)
Daschicken's Avatar
Motorcycle
Motorcycle
Motorcycle
Clutches don't just get smoked, you have to be trying to kill them. If she knows not to use the clutch to hold the car in place then it will probably be fine.
Pull the clutch in and pick the right gear!
I think you need to show her this video:
The Following User Says Thank You to Daschicken For This Useful Post:
Ecky (03-16-2018)
Old 03-16-2018, 06:55 AM   #10 (permalink)
Slushbox ecomodder
Fit_is_slo's Avatar
SloFit - '08 Honda Fit Sport
90 day: 36.63 mpg (US)
4Runner - '02 Toyota 4runner SR5 4WD
Nissan Hardbody - '96 Nissan D21 Hardbody
90 day: 25.1 mpg (US)
Originally Posted by samwichse View Post
Coil packs.
Coils definitely, hitachis off of rock auto are essentially oem ones, also I’ve had two alternators fail over the last decade I’ve had mine, but otherwise an amazingly reliable car, mine has never seen a tow truck since it was delivered 181k later
