Old 12-04-2011, 05:15 AM   #11 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Ok so that took literally about 3 seconds to download. Awesome.
I made a GIF from screencaps. This is my best effort at the current state of the Anal Probe. Not bad if I do say so.
Funny thing though. My tuft tests suggested attached flow on the rear window. I'm going to have to play with this a bit more to make it more accurate.
Super excited to play with this more when I have some time.
Edit: I think perhaps the default 100/250 settings could be accurate because that shows the kind of flow I'd expect to see based on tuft testing results.
Edit 2: I love this damn program so much. Awesome.
Edit edit: replaced with 120/45
The Following User Says Thank You to Sven7 For This Useful Post:
CigaR007 (12-04-2011)
Old 12-04-2011, 05:58 AM   #12 (permalink)
Sven7's Avatar
And I might add it is important to put the ground plane in there. I did it both ways and if it's not there the airflow from the bottom is all messed up.
Also from what I can gather the program does not like spaces in the file names.
Old 12-04-2011, 11:24 AM   #13 (permalink)
Questions I have is :
What viscosity number does the air resembles?
What Inmoci..ty equal what speed mph?
Stefan
Sorry, new users are not permitted to post links in their signatures.
Old 12-04-2011, 01:14 PM   #14 (permalink)
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Don't be fooled into thinking that the air around your car is going to be going a certain way at a certain speed. From 10mph - 300 mph, it will look essentially the same. It is a common misconception that speed changes the pattern of how the air flows, but it doesn't.
It seems the Viscosity and Incomingvelocity both change the Re number being used in this simulator, so viscosity and velocity both are changing the "air".
It is only my studied opinion of this that makes me say 120/45 looks best to me. I have thought about this a lot, it is a very educated guess based on having played with the old program for at least 100 simulations using several templates.
I can tell you that using 250/100 looks to me like a vehicle going through 20 weight oil at 90 mph, or a one the size of a blimp going through air at 20mph. you wouldn't get 90% of the air from the top hitting the tailgate like that. You would want to tune it so you get the bottom 20% of the flow hitting the top of the gate, and no closer than the 18" to it.
I'll work up some "Good/Bad" examples later today and post them.
One thing I'm not happy with, it seems no matter what the setting, it does not yield a wake behind the vehicle which matches real world. The wake area creeated is too low to the ground and too dense. So all this could be a discussion in futility in that this is NOT a wind tunnel simulator, it is really just a toy to make images of flow around stuff.
Did I mention that you need to have a decent amount of space above the model too?? I think your probe is too close to the top and it is creating a venturi type effect.
The Following User Says Thank You to ChazInMT For This Useful Post:
Sven7 (12-04-2011)
Old 12-04-2011, 01:49 PM   #15 (permalink)
Sven7's Avatar
Ok, good to know. I'll mess around with it later. And will add more height to the Probe. Otherwise, yeah, it's crashing a lot. Don't know if that's just my computer or if it's the program...
Old 12-04-2011, 01:52 PM   #16 (permalink)
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
*edit* I got it.
Old 12-04-2011, 02:06 PM   #17 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Glad to see that this works on my MacBook Pro using the Windows partition !
A thousand thanks guys !
Old 12-04-2011, 02:40 PM   #18 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z Base
90 day: 42.95 mpg (US)
Originally Posted by ChazInMT
Here is a stock 4dr Echo with the same "treatment" and settings.
Holy moly ! Quite turbulent at the back then.. Thanks.
Old 12-04-2011, 03:13 PM   #19 (permalink)
interesting
Old 12-04-2011, 03:44 PM   #20 (permalink)
The only problem I have is that with the viscosity at 45 I get alot of air separation off the rear spoiler and the top of the car. That I don't think it happens in the real life.
Stefan
