Old 10-16-2023, 09:27 PM   #1 (permalink)
War Pig - '01 Ford Taurus SEL
Ford Explorer 5.0 Proposal
What is your guys thoughts on attempting a mid to mild mpg build on a 2001 5.0 explorer? 13/18 avg stock mpg
If I choose this route almost everything on the vehicle will be rebuilt or replaced. Suspension, balal joints, rear axles, brakes, fluids, full engine and transmission rebuild. I want it to basically be "new".
For the engine I'd do a rebuild. I would mill off 30 thousands of the heads increasing compression ratio to 9.6/1. Mildly increase initial and base timing. Electric fan. Full synthetic oil. Keep or replace with the milder explorer cam and not replace with the GT hotter cam. EGR block. Any other ideas?
Replace the AWD system with the F150 4x4 system. It does not seem to difficult to achieve and seems to greatly increase drivetrain efficiency.
Replace rims with equal size lighter weight rims. Build a front aero under tray/off-road engine protector.
Any other ideas, what kind of MPG could I expect off this build? Or maybe go with a SUV that's already more fuel efficient?
First: 2001 Ford Taurus Eco Build Thread
http://ecomodder.com/forum/showthrea...s-33334-2.html
Old 10-16-2023, 11:16 PM   #2 (permalink)
Growin a stash
My parents had one of those. I wouldn't do it unless you really like the vehicle.
Theirs was mechanically reliable but the interior was falling apart. Big time clunker.
Maybe a Subaru would be better?
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
Old 10-18-2023, 05:41 AM   #3 (permalink)
90 day: 82.26 mpg (US)
It's hard to start with a less efficient vehicle, so from that perspective, I guess there's a lot of low hanging fruit. I second ME_Andy's opinion. Do it if you love it. There are few enough vehicles on the road anymore that are easy to love.
Old 10-19-2023, 10:30 PM   #4 (permalink)
If you replace the AWD with a part-time 4WD, get free-wheel hubs, otherwise it will still have too much drag from the front differential.
As far as the electric fan goes, it can do wonders.
Old 10-19-2023, 10:44 PM   #5 (permalink)
I will definitely have to look into that further! Thank you I wouldn't of thought of that
Old 10-20-2023, 09:44 AM   #6 (permalink)
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
If you don't need a 4wd I would go wild and put a massively small rear ratio in the rear end. That would be the benefit of owning a Ford. Limitless rear gear capabilities. I was averaging 25mpg in a 3.0 Ford Ranger with 3.73s but i bet with 3.08s or below i could've been at 30's. That's kinda my least favorite part about my Sequoia is no available gear swaps to decrease rpm's.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
Old 10-20-2023, 10:53 AM   #7 (permalink)
Unsure gearing will help a ranger, maybe the later round nose ones.
Old 10-20-2023, 11:49 AM   #8 (permalink)
Gearing is one of the biggest changes you can make to a vehicle. For the most part, taller gearing will almost always help mpg on the highway. I'm used to a 95hp 4cyl truck so with an explorer making more than double the power I could probably get away with taller gearing, even if only go a little taller.
However I wonder how it would affect city milage???
Old 12-29-2023, 01:02 AM   #9 (permalink)
I can't seem to upload a picture but I gave up on the idea until I found a grandma owned 5.0 explorer. The thing is mint. Transmission had been rebuilt. It's just mint and with very few flaws. Came with a set of new tires. $4300. 157k miles. I'ma start a new thread. It will start off as a maintenance thread (naturally) but slowly turn into an MPG thread with my plans
Old 12-29-2023, 01:31 AM   #10 (permalink)
90 day: 33.31 mpg (US)
90 day: 62.22 mpg (US)
I mean, I'm interested to see what becomes of the project, just as I'd be interested in what someone can do with an M1A1 Abrams tank.
