Old 04-18-2018, 08:48 AM   #1 (permalink)
Forget The CB750's, CB900C Trike Ideas!
95 HP, 10 speeds (The 750's 5 speed plus a two speed behind), Can be bought cheap from $1,000 up, Reverse Trike?
Use the full bike minus the forks behind the passenger. Still want to use combination clutch pedal/shifter pedals.' but clutch pedal and paddle shifters would be OK.
Old 04-18-2018, 12:04 PM   #2 (permalink)
Well, it won't be a T-Rex, but bit should go pretty good. Here's the gear ratios for both high and low ranges of the transmission:
Name:	CB900C Gear Ratios.jpg
Old 04-18-2018, 01:54 PM   #3 (permalink)
This seems more easily doable, but how do you plan to couple the CB engine to the 2-speed transmission?
Old 04-18-2018, 03:30 PM   #4 (permalink)
The CB900c already had it. I don't think they made them for very many years. Don't recall if they were shaft drive or not, shaft would be nice, but couldn't play with gearing as easy as chain.
I'd try to find a newer wrecked bike if I was going to attempt something like this. A Suzuki 1200-1250 bandit would be a good choice.
Old 04-18-2018, 06:09 PM   #5 (permalink)
They were shaft drive, and the 2 speed sub transmission, as they called it, was part of the bike. I would keep everything, short of the forks, as it comes. They upgraded this in '83 to a CB1000C, but these are probably much more expensive. Both the 900C and the 1000C are bored and stroked versions of the 750
Old 04-18-2018, 07:16 PM   #6 (permalink)
Smokey - '13 Chevrolet Cruze Eco
Are you sure you can change the H/L lever at speed? It would be great if you can. Their were dual sports with the H/L range trans as well.
Old 04-18-2018, 08:34 PM   #7 (permalink)
I was 15-16 dealer let me test ride a used 1983 CB1100F, we might of had the gs550l, but nothing in comparison. Wish I had any money at the time, but I'd probably wouldn't be here today. Still on my dream bike list.
Old 04-19-2018, 12:02 AM   #8 (permalink)
Yes, but some steps are so close together (3rd High [6.37] to 4th low [6.14], and 5th low [5.26] to 4th high [5.25]) that it is quicker to skip them. I've come up with seven gears that may be the quickest acceleration run (See the diagram in post number 2, this thread)
Old 04-19-2018, 12:07 AM   #9 (permalink)
Some can be bought for as little as $1,600.
https://www.smartcycleguide.com/L48000889
Old 04-19-2018, 08:58 AM   #10 (permalink)
Not totally impossible though, even if that could involve working around some Ford 9-inch differential...
But anyway, I'd be more concerned about a provision for reverse gear. Maybe electric reverse like in the GoldWing and some BMW motorcycles?
