Old 10-29-2012, 04:11 PM   #11 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
Originally Posted by mrsilent13 View Post
well in that case after reading that....i guess ill stick to 2.73 for now
If you want better highway, you'll want to deop it even firther. i have the 2.7s and replaced my 17s with 18s. Pick up tire size, and highway cruising becomes more fuel efficient(for the most part).
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 10-29-2012, 04:12 PM   #12 (permalink)
Ruby - '91 Ford Mustang LX
90 day: 21.09 mpg (US)
Dusty - '03 Volkwagen Passat
Stella - '04 Saab 9-5 Aero
yes i got rid of the engine driven clutch fan that was stuck anyway...so i installed a complete stand alone unit with built in thermostat...between 180-220....would it be a good idea to turn the thermostat up to have the heat do more of the burning..i currently have it set to 180...i guess ill try that experiment out once i get the MPGuino to see if theres an actual difference...but on the highway it wont make a difference
Old 10-29-2012, 04:15 PM   #13 (permalink)
yes im thinking of doing an air dam/grill block...havent really looked well into it...but i am thinking about it
Old 10-29-2012, 07:57 PM   #14 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
He's right.
Even going up a size on the 15s will help.
See my threads in my signature.....
245/45/18 is stock
am running 245/50/18 on stock rim
went from 26" to 27.5" in diameter.
keeps my rpm low at highway speeds.
It will slow down your 'launches' but hey.......
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 10-29-2012, 07:59 PM   #15 (permalink)
mcrews's Avatar
dont need a vacuum gauge if your running the MOGuino
ECO MODS PERFORMED:
First: ScangaugeII
The Following User Says Thank You to mcrews For This Useful Post:
mrsilent13 (10-29-2012)
Old 10-29-2012, 08:04 PM   #16 (permalink)
well i am running 225 55 16 i guess going a size up on the rears and leaving the front stock would not affect it too much...or do i need to swap all 4 tires for the taller size?
Old 10-29-2012, 08:17 PM   #17 (permalink)
Hydrogen > EV
You want to swap the drive axle, so rears for you. And there is a terminal point where bigfer tires will be more harm than help, but i don't think a reasonable person will encounter that. If you do 16s front, 17/18 in back, you will help lower engine rpm, and create a low pressure zone under rhe rear of the care- more downforce, in theory, but that, in theory, means more drag.
Edit:
From my limited time on the site, mcrews knows his stuff. His guides are pretty good, and you might want to go his and my route and buy a more aero efficient front fascia. Just an idea.
Best Tanks:
The Following User Says Thank You to UltArc For This Useful Post:
mcrews (10-30-2012)
Old 10-29-2012, 08:20 PM   #18 (permalink)
yes im looking at getting a GT front or at least something to create the air dam
Old 10-29-2012, 08:25 PM   #19 (permalink)
GRU
GRU's Avatar
silver bullet - '00 Honda Civic
90 day: 34.41 mpg (US)
keep the stock gears because if you go to 3.55 you will get worse mileage on the highway....look into some aero mods, i'm sure for the mustang there are some front air dams that look good and divert the air from going under the car...or do a belly pan
Old 10-29-2012, 08:46 PM   #20 (permalink)
yes im actually looking at mcrews belly pan right now...that thing is amazing
The Following User Says Thank You to mrsilent13 For This Useful Post:
mcrews (10-30-2012)
