Old 07-26-2008, 12:43 AM   #1 (permalink)
Polymer - '89 Honda Civic Hatch Std 4 speed
Woodstock - '69 MG Midget 1275
Nekobus - '06 Scion xB
Fuel Cut/Engine Shutoff Switch (Failed Attempt!)
'89 Civic 1.5L M/T
Well, today I failed to install a fuel cut/engine shutoff switch.
I bought a 25A switch for the dash and wired it up between the main relay and the injectors/fuel pump.
It cuts off the injectors and fuel pump just fine (I thoroughly checked/researched the Chilton manual to be sure of this). I thought that the worst it could do is throw an injector code on the ECU and then the injectors would re-activate when the switch was flipped back. WRONG.
Removing power from the injectors causes the ECU to flip out and not let the engine back on when I drop the clutch. (and it _does_ throw the injector code and activate the check engine light) So I basically still have to turn the ignition off and back on again, which defeats the whole purpose of the switch.
I've found a different place to wire the switch in, that should cut off more than JUST the injectors and fuel pump. It's the main 10A fuse that is only powered during RUN and START. (fuse 14 - for future reference)
I'll give 'er another go tomorrow. Hopefully with less mosquitos attacking me.
Old 07-26-2008, 01:23 AM   #2 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
Them skeeters get worse every year.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 07-26-2008, 03:40 AM   #3 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
millenniumtree -
You need yourself a handfull of these :
F & T Fur Harvester's Trading Post - Novelty Mosquito Trap
I have to do that mod also. I have heard that Saturn ECU/PCMs don't care if the fuel injectors cut out, but I have no personal experience that this is true.
CarloSW2
American Solar Energy Society
Old 07-26-2008, 08:22 AM   #4 (permalink)
I'd recommend just cutting the injector signal, not the fuel pump. Fuel pressure should still remain during coasting, but I just don't see a reason to cut power to the pump.
The Following User Says Thank You to Daox For This Useful Post:
j12piprius (02-24-2011)
Old 07-26-2008, 09:27 AM   #5 (permalink)
I think I'd get the same result if I just cut the injectors. Both injectors and pump are on a common wire, and I think the ECU would still freak out if I killed just the injectors.
I'm going to try today to tap into the fuse 14 output and I'll let you know how it goes.
Old 07-26-2008, 05:44 PM   #6 (permalink)
Did you get that thing?
reformed's Avatar
Green Machine - '92 Honda Civic LX
90 day: 39.98 mpg (US)
Money pit - '97 Infiniti j30
90 day: 22.74 mpg (US)
Much better off cutting the spark instead of the gas IMO. The blue wire at the distributer, should do the trick on your car.
Old 07-26-2008, 07:22 PM   #7 (permalink)
Success Thread
http://ecomodder.com/forum/showthrea...cess-4076.html
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
Hydrogen Generator Experiment willy57 DIY / How-to 601 08-23-2016 05:53 AM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 40 06-18-2012 03:13 AM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 02:04 PM
