Old 11-08-2010, 07:08 PM   #1 (permalink)
VX Padawan
VX du Slog - '94 Honda Civic VX
Fuel injector modification?
Saw this on eBay, and wondered if there was anything to it. Supposedly this guy refurbishes and modifies fuel injectors for better economy.
Link to auction
Anyone heard of this?
Old 11-08-2010, 11:21 PM   #2 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
While i dont know much about injectors, fluid dynamics states that a fluid of an equal volume and pressure forced through smaller orifices will create a finer spray.
just my $0.02
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 11-08-2010, 11:31 PM   #3 (permalink)
Bus - '94 Ford School Bus huge
Stupid - '01 Chevy Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Honda Superhawk
He really isnt making the mods. He is just buying injectors that are standard on all indirect injection vehicles today.
Old 11-09-2010, 10:38 AM   #4 (permalink)
VX Padawan
Interesting... so is it possible to source these myself? It's a little expensive for me to experiment with, but I'm sure my injectors are tired after 200k miles. =)
Old 11-09-2010, 08:16 PM   #5 (permalink)
White Lightning - '98 Ford Ranger XLT Off Road
There are some aftermarket injectors for the jeep straight 6 that has a better flow pattern that does help with fuel mileage. I would like new injectors for my truck but at $65 each I think I will wait until they are a problem.
I have to point out though that depending on the port shape of the engine, a wider finer spray pattern is not always as good because more fuel will collect on the port walls.
1998 Ford Ranger 4.0L 4x4
Old 11-09-2010, 08:53 PM   #6 (permalink)
You can pick up some from the junk yard. You would need to find out your flow rate and then the vehicles that have the desired injectors.
Old 11-11-2010, 04:55 AM   #7 (permalink)
discovery's Avatar
It is the ECU most important for FE. Injectors and all the sensors are part of it
Honda Insight Parts For Sale
http://imageshack.us/g/1/10087943/
http://imageshack.us/g/1/10087939/
Bought Accord 88 LX'i on ebay.com for $380
Check out our Honda build
http://www.3geez.com/forum/showthread.php?t=67592
Also check out the Scooter we bought for $300- 92MPG
http://scootdawg.proboards.com/index...y&thread=32692
Old 11-11-2010, 09:22 AM   #8 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I wouldn't attribute a lot of savings to these. I would really only consider it if you were going on a no-expense-barred-uber-sweet-super-fe build.
Old 11-11-2010, 03:28 PM   #9 (permalink)
ncs
RockMagnet - '04 Subaru Impreza wagon WRX
90 day: 26.16 mpg (US)
Since most of us are driving older vehicles, I'll ramble on in that direction.
As injectors get old, the get dirty, clogged up with the various stuff that's in gasoline. It alters the spray pattern and flow rates. The change in flow rates aren't always equal between the injectors. That means an imbalance charge between cylinders and a less efficient burn.
The closed loop system that uses an oxygen sensor for feedback only measures the total air fuel ratio. If one cylinder is +5% and another is -5%, the computer will never know.
I suspect that cleaning the stock fuel injectors would nearly identical results as buying these upgrades. Some shops keep a large inventory and will send back flow tested and matched injectors. Factory injectors can vary quite a bit, even when new.
Old 11-11-2010, 05:47 PM   #10 (permalink)
imported Appalachian
Yoda - '97 Toyota Corolla Base
90 day: 30.51 mpg (US)
She-Ra - '03 Honda Accord EX
90 day: 22.91 mpg (US)
Thor - '04 Toyota 4Runner SR5
90 day: 18.26 mpg (US)
I have looked at a few sites that do Fuel Injector cleaning.
WitchHunter Performance - Injector Cleaning & Flow Testing Services
The concept looks pretty basic, but has anyone actually used one of these services?
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 29 09-06-2018 03:09 PM
mileage computer for a carbureted engine diesel_john Instrumentation 221 05-01-2014 10:38 PM
Fuel Warmer and Fuel magnet? boostanddestroy EcoModding Central 42 04-25-2010 04:48 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
