Old 06-29-2008, 02:20 AM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Fun and/or Games
You know you are bored when you find yourself re-implementing conways Game of Life on your mpg gauge
Lot more cells on the 4x20 though
(spoiler) It never ends very well
here is the 2x16 code, play with the 1s and 0s in the display[] to set the starting pattern.
PHP Code:
//GPL Software
#include <avr/pgmspace.h>
/* Death
If an occupied cell has 0, 1, 4, 5, 6, 7, or 8 occupied neighbors, the organism dies (0, 1: of loneliness; 4 thru 8: of overcrowding).
Survival
If an occupied cell has two or three neighbors, the organism survives to the next generation.
Birth
If an unoccupied cell has three occupied neighbors, it becomes occupied.
 7 0 1    how I'm referring to neighbors
6_\|/_
  /|\  2
 5 4 3
#define brightness 180 //middle button cycles through these brightness settings
#define contrast 15
//LCD Pins
#define DIPin 4 // register select RS
#define DB4Pin 7
#define DB5Pin 8
#define DB6Pin 12
#define DB7Pin 13
#define ContrastPin 6
#define EnablePin 5
#define BrightnessPin 9 //control with a transistor please if you use it
typedef void (* genericFx)(void);//type for function pointers
genericFx resetFunc 0;
//LCD prototype
class LCD{
public:
LCD( ) ;
void gotoXY(byte xbyte y);
void print(char string);
void init();
void tickleEnable();
void cmdWriteSet();
void LcdCommandWrite(byte value);
void LcdDataWrite(byte value);
byte pushNibble(byte value);
LCD lcd;
int powerUp MCUSR &1;  //did we reset or power up?
#define rows 6
#define columns 16
byte tmp [] = {
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0};
byte display [] = {
0,0,1,1,0,0,0,0,0,0,0,0,0,0,0,0
0,0,0,0,0,0,0,0,0,0,0,0,0,0,1,1
0,0,0,1,0,0,0,0,0,0,0,0,0,0,0,0
0,1,0,1,0,0,0,0,0,0,0,0,0,0,0,
void loop (void){
lcd.init();
byte running=1
  while(
running==1){
unsigned long loopStart=millis();
running=0
//  update the neighbor counts
for(int y 0rowsy++){
      for(
int x 0columnsx++)
tmp[y*columns+x]=getNeighborCount(display,x,y);
//display the array
for(int y 0rowsy+=3){
lcd.gotoXY(0,y/3);
      for(
int x 0columnsx++){
byte n1=display[y*columns+x];
byte n2=getNeighbor(display,x,y,4)*2
byte n3=getNeighbor(display,x,y+1,4)*4
lcd.LcdDataWrite(n1|n2|n3);
//see who lives and who dies
      for(
int x 0columnsx++){
byte b display[y*columns+x];
byte n tmp[y*columns+x];
        if(
b==0){
          if(
n==3) {
display[y*columns+x] = 1//birth
running=1
        }else{
          if(
n==|| n==3)
display[y*columns+x] = 1//survival
else {
display[y*columns+x] = 0//death
running 1
lcd.gotoXY(0,0);
lcd.print("DONE");
delay(1500);
resetFunc(); //poor mans reset :)
byte getNeighborCount(byte a[], byte xbyte y){
byte c 0
  for(
byte d 0;8d++)
    if(
getNeighbor(a,x,y,d) != 0
c++;
  return
c
byte getNeighbor(byte a[], byte xbyte ybyte dir){
byte nx=x
byte ny=y
  if(
dir == || dir == || dir == 1)
ny--;
  if(
dir == || dir == || dir == 5)
ny++;
  if(
dir == || dir == || dir == 7)
nx--;
  if(
dir == || dir == || dir == 3)
nx++;
  if(
nx==255nx columns 1
  if(
nx==columnsnx 0
  if(
ny==255ny rows 1
  if(
ny==rowsny 0
  return
a[ny*columns+nx];
//get a string from flash
char mBuff[17];//used by getStr
char getStr(prog_char str){
strcpy_P(mBuffstr);
  return
mBuff;
//LCD functions
LCD::LCD(){
//x=0..16, y= 0..1
void LCD::gotoXY(byte xbyte y){
byte dr=x+0x80;
  if (
y==1)
dr += 0x40;
  if (
y==2)
dr += 0x14;
  if (
y==3)
dr += 0x54;
lcd.LcdCommandWrite(dr);
void LCD::print(char string){
byte x 0;
char c string[x];
  while(
!= 0){
lcd.LcdDataWrite(c);
x++;
string[x];
//do the lcd initialization voodoo
void LCD::init(){
LcdCommandWrite(B00000010);  // 4 bit operation
LcdCommandWrite(B00101000);// 4-bit interface, 2 display lines, 5x8 font
LcdCommandWrite(B00001100);  // display control:
LcdCommandWrite(B00000110);  // entry mode set: increment automatically, no display shift
//creating the custom fonts:
LcdCommandWrite(B01000000);  // set cgram
static byte chars[] PROGMEM ={
B00000,B11111,B00000,B11111,B00000,B11111,B00000,B11111,
B00000,B00000,B00000,B00000,B00000,B00000,B00000,B00000,
B00000,B00000,B11111,B11111,B00000,B00000,B11111,B11111,
B00000,B00000,B00000,B00000,B11111,B11111,B11111,B11111,
B00000,B00000,B00000,B00000,B11111,B11111,B11111,B11111};
    for(
byte x=0;x<8;x++)
      for(
byte y=0;y<8;y++)
LcdDataWrite(pgm_read_byte(&chars[y*8+x])); //write the character data to the character generator ram
LcdCommandWrite(B00000001);  // clear display, set cursor position to zero
LcdCommandWrite(B10000000);  // set dram to zero
void  LCD::tickleEnable(){
// send a pulse to enable
digitalWrite(EnablePin,HIGH);
delayMicroseconds(1);  // pause 1 ms according to datasheet
digitalWrite(EnablePin,LOW);
void LCD::cmdWriteSet(){
digitalWrite(DIPin,0);
byte LCD::pushNibble(byte value){
digitalWrite(DB7Pinvalue 128);
value <<= 1;
digitalWrite(DB6Pinvalue 128);
value <<= 1;
digitalWrite(DB5Pinvalue 128);
value <<= 1;
digitalWrite(DB4Pinvalue 128);
value <<= 1;
  return
value;
void LCD::LcdCommandWrite(byte value){
value=pushNibble(value);
cmdWriteSet();
tickleEnable();
cmdWriteSet();
tickleEnable();
delay(1);
void LCD::LcdDataWrite(byte value){
digitalWrite(DIPinHIGH);
tickleEnable();
tickleEnable();
delay(1);
void setup (void){
MCUSR=0
Serial.begin(9600);
pinMode(BrightnessPin,OUTPUT);
analogWrite(BrightnessPin,255-brightness);
delay(500);
pinMode(EnablePin,OUTPUT);
pinMode(DIPin,OUTPUT);
pinMode(DB4Pin,OUTPUT);
pinMode(DB5Pin,OUTPUT);
pinMode(DB6Pin,OUTPUT);
pinMode(DB7Pin,OUTPUT);
delay(500);
  if(
powerUp)
lcd.init();
pinMode(ContrastPin,OUTPUT);
analogWrite(ContrastPin,contrast);
lcd.LcdCommandWrite(B00000001);  // clear display, set cursor position to zero
lcd.LcdCommandWrite(B10000000);  // set dram to zero
lcd.gotoXY(0,0);
lcd.print(getStr(PSTR("Game of Life")));
lcd.gotoXY(0,1);
lcd.print(getStr(PSTR("  mpguino style")));
delay(1500);
More fun mpg 93DelSol Introductions 7 08-09-2008 07:04 PM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 03:16 PM
Just for fun: What were your parents' first cars? Peakster The Lounge 5 03-27-2008 12:24 PM
Fun and 50 mpg: Who needs a Prius? tasdrouille Hypermiling / EcoDriver's Ed 9 02-15-2008 12:44 PM
Article: Smart car offers fun along with fuel efficiency MetroMPG General Efficiency Discussion 0 01-29-2008 08:39 AM
