Old 06-07-2021, 03:25 PM   #1 (permalink)
90 day: 51.82 mpg (US)
Fun: help ID this old forged mystery item found under my house
I was excavating under my kitchen to do foundation repair and found miscellaneous old junk thrown into the back fill when the house was made (~80-100 years ago). Stuff like old bottles, broken tools, cans.
Most of the back fill seems to be foundry waste - course clinker chunks. (There was a major foundry in this town way back when, and I guess clinker was readily available, and the foundry was happy to get rid of it.)
But this mystery bit of forged hardware looks hand-made - not foundry produced.
Everyone I've showed it to is stumped. Any ideas??
This hole looks like it may have been square originally. Corners filled in with rust? For a carriage bolt?
The outer holes are beveled on this side (for counter-sunk screws?).The middle hole looks simply punched through.
Some elaborate handle?
Name:	2021-06-07 15.06.08.jpg
ID:	30812   Click image for larger version
Name:	2021-06-07 14.58.59.jpg
ID:	30813   Click image for larger version
Name:	2021-06-07 14.57.28.jpg
ID:	30814   Click image for larger version
Name:	2021-06-07 14.58.09.jpg
Old 06-07-2021, 03:36 PM   #2 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
It's the spraxial entubacricizer from a turbo encabulator.
The Following User Says Thank You to samwichse For This Useful Post:
MetroMPG (06-07-2021)
Old 06-07-2021, 05:18 PM   #3 (permalink)
I was going to say coat hook, but let's go with samwichse's theory.
Old 06-07-2021, 06:07 PM   #4 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Stirrup? But that's pretty heavy gauge for that use..
Old 06-07-2021, 07:14 PM   #5 (permalink)
Thalmaturge
I mean seriously, it seems like a carriage bolt was meant to go through the two aligned holes. Two chamfered holes mean the plate part was mounted to wood, but to the inside? So the carriage bolt would have gone through the wood. No idea.
Old 06-07-2021, 09:37 PM   #6 (permalink)
Yup, the two countersunk screws seem to be on the wrong side.
Maybe that's why they threw it out. :-D
Old 06-07-2021, 09:54 PM   #7 (permalink)
90 day: 29.78 mpg (US)
My first thought was coat hook, then sturrup. I've got no other ideas.
Old 06-08-2021, 09:28 AM   #8 (permalink)
Pipe hangar. It nails to the stud or joists from the outside between studs or joists They didn't have plumbers tape back then and cast iron is easy to cast and cheap. Spacing is about right for actual 2x4. Center hole is for vertical use keeping pipe in place
Old 06-08-2021, 11:06 AM   #9 (permalink)
Interesting. But I'd think a pipe hangar would be a high volume, mass-produced item. This looks handmade.
(Then again, horseshoes were handmade...)
Old 06-09-2021, 09:59 AM   #10 (permalink)
With the proper investment casting you could do maybe 10-20 at a time since there would not be an appearance requirement.
Not sure a cast iron horseshoe would hold up very long. The important part of blacksmithing is removing the carbon by reheating and impact welding
MetroMPG (06-09-2021)
