Old 11-22-2010, 09:18 PM   #1 (permalink)
Building the future! :-)
Belaero Build Thread, Here we go again! :-)
Ok, its official, the saw has hit the steel, the chassis work has begun :-)
Im building a high mpg reverse trike with an eye on getting the most miles per dollar of overall cost to own (lots of ways to get to that, beleive me!)
My goal is to build something I can post plans to free and help people build a 100mpg plus vehicle (at 70 mph)that can carry 2 people and 6 bags of groceries.
And all for under 5k ICE only and 10k ev with 100 mile range.
The idea is to build the "forward cabin" the entire chassis forward of the rear seats back as a unit and build interchangeable rear sections. (electric and serial hybrids would be able to carry a 18" shorter wheelbase = lighter car
The first drive iteration Ill build will be 72v ev drive system 40 to 60ah of thundersky batteries and a 7hp gas engine turning a generator.
The 2 motors will be an etek-s for the drive motor, its brand new 500a for 3 minutes and 150a continuous . its like a regular eteks big brother :-)
Mars ET-RT Permenant Magnet Motor
Gen will be an etek rt slightly smaller and less expensive:
The chassis measurements under "serial hybrid / ev mode will be 78" wheelbase, 116" overall length and 55" across at the outsides of the wheels.
Here are some early build pics and odds and ends:
(the pencil drawing a) is very bad, still looking for some help with 3d modeling) :-) and b) reflects the longer wheelbase gas engine version.
150mpg here we come! :-)
ID:	7412   Click image for larger version
ID:	7413   Click image for larger version
ID:	7414   Click image for larger version
ID:	7415   Click image for larger version
Old 11-22-2010, 10:46 PM   #2 (permalink)
Electrics are usually heavier right?
Old 11-22-2010, 11:04 PM   #3 (permalink)
This first build is only going to have 40 to 60 ah (80 to 130 pounds) of batteries, a little heavier, but not ungodly heavy.
Old 11-23-2010, 12:06 AM   #4 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Looking forward to more updates
Old 11-23-2010, 10:27 AM   #5 (permalink)
It is great to see what you have done -- starting is the hardest part, in my opinion.
As we learned from Allert Jacobs DIY aerodynamic fairings on a Honda 125cc motorbike, and from the X-Prize Knockout Round results -- the weight of a vehicle is less important than the aero drag.
The efficiency of the drivetrain is the most important.
The aerodynamic drag is the next most important.
Weight is third most important.
Vehicle rolling efficiency is the fourth most important.
The reason that weight is less important than aerodynamic drag is that weight gives momentum, so while it takes more to accelerate a heavier car, it then coasts better. You inherently regain some of the energy.
Aerodynamic drag is a total loss. Rolling resistance is a total loss, too, but it is much lower magnitude and linear. Aerodynamic drag is exponential, and so it is orders of magnitude greater.
So, the challenge with your interchangeable parts will be alignment and robust strength and rigidity.
Old 11-23-2010, 11:43 AM   #6 (permalink)
downhill both ways
Toby's Avatar
Terceleporter - '96 Toyota Tercel STD
90 day: 52.6 mpg (US)
Very cool.
Out of personal curiosity I have to ask these ugly questions:
1) What about crash-worthiness?
2) How will you insure it?
3) Do you have to pass safety/road-worthiness inspections where you live?
Old 11-23-2010, 11:54 AM   #7 (permalink)
Excellent questions Toby!
Crash worthiness: I'm shooting for "Really safe motorcycle". It will be registered and insured as a motorcycle, I will get a "MSO" from one of the chopper builders on eBay (done it before).
It will have a roll bar directly over the forward riders head of rolled 1 1/4 round. and a 1x2" support over the rear riders head forming the rear bulkhead.
The frame rails extend up 16" from the floor so decent side impact protection, not "Volvo caliber" im guessing though.
The forward rider will be essencially surrounded by the front wheels so good side impact coming from the wheels and suspension itself.
The area im not in love with is the very front. The riders feet will extend about 8" past the front of the wheels. Its a consideration to balance. I will use 2x1" top and bottom there and fill the entire nose area with foam forward of the drivers feet ala tri magnum.
No inspection in FL (Im pretty sure, since its technically a motorcycle, inspections would be exempt, or strictly a function of emissions and "do the blinkers work" in other states should someone else want to build one?
Old 11-23-2010, 01:18 PM   #8 (permalink)
A safety concept that I learned from Oliver Kuttner of Edison2, is deflection (vs engagement). If you protect the people with a structure that is shaped to deflect away from the object that you are crashing into, then you will go a long way to having a safer vehicle. Look at the Edison2 Very Light Car or Formula 1 cars, etc. for what this looks like.
Old 11-23-2010, 01:27 PM   #9 (permalink)
Excellent advice Niel! Thanks.
Old 11-23-2010, 01:31 PM   #10 (permalink)
sorry, Neil :-)
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
Build Thread: 1996 Ranger 2.3L 5spd 2WD XVTer EcoModding Central 18 05-27-2012 08:39 PM
The Little Red Build Thread Oval_Overload EcoModding Central 37 09-30-2010 06:19 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
