Old 01-16-2011, 04:30 PM   #41 (permalink)
Building the future! :-)
No transmission :-)
The diesel will only be used for speeds between 45 and 75. It will be "injected" into the drive train via a centrifigual clutch.
Old 01-20-2011, 02:14 AM   #42 (permalink)
EcoBill's Avatar
Toyota Ist - '06 Scion Xa
90 day: 35.17 mpg (US)
any update? whats next to do??
I have tons of ideas....ill send you a pm tomorrow...err later today after I wake up since its 2am now
Old 01-20-2011, 12:44 PM   #43 (permalink)
Originally Posted by todayican View Post
No transmission :-)
A 45 - 75 mph single speed? Forget the clutch and add a frewheel! Clutches get hot = inefficiency but are good for changing gears. You'd need to find a way to disengage the drive train for reversing (using elect only). Stopping on hills you'll have an auto anti-roll back (if the diesel won't turn backwards?) Single speed roller chain drive is SUPER efficient!
10 Hp isn't much even with the tiny car you have planned. Look up the punsun 20-25 hp from china. They are cheap and some guys put them into diesel motorcycles (they still aren't fast). They are also light for the rated HP (air cooled). Is the ICE motor capable of the RPM range you need for the speed range you need?
Sorry I reread and it seems you are planning a series hybrid so you need the clutch to disengage the ICE for EV only operation, right? I assume you are planning rear wheel chain drive? Wait, I think you could still put a freewheel between the ICE and drive train so even if the EV is turning the drivetrain the ICE doesn't have to turn... Unless you'd want to start the ICE with the E motor.
I've really wondered about putting two motors together on one drive train. It seems like a good way to manage loads to make an efficient hybrid but I suspect there are a lot of things to be careful of... I'd suggest to PM some of the hands on and mechanical minded guys like FrankLee or dcb or arragonis.
I love this idea! Best of luck.
Old 01-20-2011, 12:59 PM   #44 (permalink)
Where might I find a freewheel with a 1" bore that can withstand that amount of torque?
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
Build Thread: 1996 Ranger 2.3L 5spd 2WD XVTer EcoModding Central 18 05-27-2012 08:39 PM
The Little Red Build Thread Oval_Overload EcoModding Central 37 09-30-2010 06:19 PM
Build Thread Key Postings Index Experiment. TestDrive Forum News & Feedback 7 02-15-2009 08:53 PM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
