Old 11-18-2010, 10:00 PM   #121 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
The polarity of the scope is correct. It was grounded to the cigarette lighter, and read +13V when I probed the power lead for the guino.
So, the INJ lead is reading 0 most of the time (there's an underscore next to the A in this image, that marks 0V). Then the pre-fire square wave is +14V for 1000 us (no matter the load, this part stays the same even after I key-off the engine and it decelerates to a stop). Then the first big negative spike, then PWM from 0 to +14V, and a second big negative spike.
Old 11-19-2010, 06:17 AM   #122 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
ok, so we want to toggle the flip flop on a falling -20v signal (I think it is still doable with just a voltage divider), then adjust the Injector DelayuS to 0 and see what happens.
Just curious, are you sure the thing was still firing with the key off and that the scope wasn't just freezeframing on the last known signal?
Old 11-19-2010, 11:36 AM   #123 (permalink)
in tents
dennyt's Avatar
Subaru
Yeah, it's interesting. When I rev the engine then let off the gas, the right half of the signal goes away but that square pre-fire shape is still there until the engine slows down to idle & needs fuel again. Same thing when I key it off, I think the pre-fire happens even when the injector isn't opening. Weird.
Old 11-19-2010, 11:32 PM   #124 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Geo Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 Suzuki DR650SE
90 day: 55.26 mpg (US)
Send a message via MSN to Coyote X
The opamp circuit in post 103 works with the gm tbi peak and hold injectors with the addition of a capacitor on the avr input pin and to ground. This keeps it from missing pulses and it seemed more or less right on mine. I can't test it any further though since it is no longer gas.
I can't remember what size cap it was but it was a small electrolytic. It was just enough to smooth out the small gap on the very short pulse width signals that the mpguino would miss the interrupt on.
I still have some of the current sensing chips I ordered and never uesd. I could send them to you if you want them dcb. Just let me know and I will send them to you to play with.
The Following User Says Thank You to Coyote X For This Useful Post:
dcb (11-20-2010)
Old 08-21-2011, 07:08 PM   #125 (permalink)
The Beast - '93 Fleetwood Flair includes kitchen sink
90 day: 9.2 mpg (US)
The Bigger Beast - '03 Winnebago Sightseer Motor Home
lm339 comparator.
Originally Posted by dcb View Post
not until someone with a tbi tries it at least.
I built this circuit today. It does square up the signal quite well. My design is a 2X2 perf board with the IC in the middle of it. I robbed a power connector from an old 31/2" floppy drive for the signal input and clipped a power supply cable from a dead power supply with the 4 pin connector to plug into the MPGuino.
I used direct connections to the other components.
Now all I have to do is wait for the gas price to go down to fill the beast up. Over 60 gallons. OUCH!
Then I can run some mpg tests.
I'll post my o'scope pictures on my website below.
Lee
crazycomputers dot com/Fleetwood_Flair_26/]1993 Fleetwood Flair
Old 09-08-2011, 03:32 AM   #126 (permalink)
@dennyt
I have started a thread about my software soultion for peak and hold in the following thread
http://ecomodder.com/forum/showthrea...tml#post258881
You can see my peak and hold appears to be the inverse of yours, but it may be of use to you, maybe inverse the triggers?
Old 10-04-2011, 10:27 PM   #127 (permalink)
Comparitor Circuit didn't Work
I tried the comparitor circuit. I built it on a perf board and put the IC in the middle.
Here is the picture.
I used one 4 pin plug and one 4 pin jack to allow it to be easily removed or added in.
I found that the circuit squared off the whole wave form from the injector.
Here is a scope trace
Chevy 454, TBI, @ 2000 RPM. Top trace injector pulse, bottom, comparitor signal.
The result was I was showing 50 MPG! That's on a large motor home.
I think it was counting the narrow pulses as the injector signals, not the wide pulse.
Maybe some bias circuit would get the actual pulse width modulation we want.
I tried a variable resistor in the cold side of the reference voltage to adjust the switching point, but that didn't do the job.
I also tried a transistor inverter circuit between the injector pulse and the comparitor input but that didn't work either. I haven't had time to check out why yet. I wanted to see if the flipped signal would be accepted by the MPGuino.
I am going to try the filter circuit next. I'll build it on the perf board.
Lee
Old 10-05-2011, 12:39 AM   #128 (permalink)
dcb
needs more cowbell
dcb's Avatar
the comparitor is not picking up the hold portion of the injector signal.
so you can't fiddle with that potentiometer and get a longer low pulse out of the comparitor? Have you looked at the opto-isolator version?
Old 10-05-2011, 05:44 PM   #129 (permalink)
Comparitor signals.
I'll check it out. The comparitor picks up all of the positive portion of the injector pulse. I need to bias the signal so it only sees the middle to the top. Then it will see only the pulse width.
I am adding a variable resistor to a B- to Injector in and a blocking capacitor to the ECU input signal to lower the signal B-. I may have more to do.
I hope to lower the signal so the bias is set lower than -5 to -15 volts so all the comparator will see the actual pulse width.
I need a - 15 volt source. I am trying a - volt pump from the actual injector pulse! I'll keep you posted.
Old 04-05-2012, 01:44 AM   #130 (permalink)
Active Learning - '93 Chevy Suburban Silverado
90 day: 10.67 mpg (US)
this is like a good book that someone ripped the last 3 pages out of. lol did it work?
Pulse & Glide / EOC: Anyone rated their gallons per hour @ 0mph? dissimilation Hypermiling / EcoDriver's Ed 27 07-19-2010 03:12 AM
Slight error Johnny Mullet Forum News & Feedback 3 07-22-2008 04:05 PM
How Many Gallons Per Week? LostCause The Lounge 24 05-06-2008 10:02 AM
Tolls to limit rush hour driving? SVOboy General Efficiency Discussion 10 04-27-2008 04:12 AM
Fuel log error diamondlarry Forum News & Feedback 3 04-19-2008 03:38 PM
