04-18-2011, 03:40 PM
My Goal: 35 MPG All Day
Gas goes up, Car weight goes down
So since gas is getting so high lately and I deliver in my car, I decided to get my car to loose some weight... Here is whats going on so far.
Weight of each thing is based on using both of the scales we have at home, nothing fancy so I cant say its to the oz but it should be close measurements...
10.6 lbs..... Taking out the bottom part of the back seat
23.6 lbs..... Taking out the top part of the back seat
07.4 lbs..... Taking out the piece that covers the spare tire
03.6 lbs..... Taking out the rear floor mats
02.8 lbs..... Taking out the giant jumper cables I got
26.4 lbs..... Taking out the spare tire
00.5 lbs..... Random crap sitting in car I didn't need
02.3 lbs..... Passenger side-side view mirror (Electric)
77.2 lbs Total
Will update any of this if I pull more stuff
Also: Geez, nothing like gas going up a ton to make you start watching that SGII like I hawk again eh? haha
The Following User Says Thank You to RandomFact314 For This Useful Post:
04-18-2011, 04:00 PM
Moderate your Moderation.
Pasta - '96 Volkswagen Passat TDi 90 day: 45.22 mpg (US)
I always like to see weights posted for a weight reduction. If you don't normally carry a passenger, you can take out that seat, too. It goes back in quickly, should you need it.
04-18-2011, 04:03 PM
Me and my girlfriend take turns with cars as far as driving around to get groceries or food so Id have to keep that one in there, would be too much work to take it out and put it back in every other day
04-18-2011, 04:04 PM
I'm considering a quick release for the partner seat on my golf... None ever ride with me, so it's extra weight/less space.
04-18-2011, 04:07 PM
Yeah when I had my neon and my fiero that my girlfriend never wanted to ride in but did occasionally I was thinking about using like hood clips to hold the seat in and I could quickly take them out or put them back in. If they can hold a hood down safely you could use 4 to hold a seat down eh?
04-18-2011, 04:16 PM
Some other things you can save weight with:
Spare/tools -replace with plug kit and small air compressor
Rubber foot pads on the pedals
Fixed glass - poly-acrylic
Seats: suspension seat rebuild
Exhaust: pre-muffler/resonator if equipped
Cut the plastic behind your air dam
There's more, but some involves cutting/drilling parts
Urethane is typically lighter than rubber, for bushings, but dont go out of your way to replace ones that don't need it.
04-18-2011, 04:20 PM
in tents
With effective anticipation of lights & stop signs (i.e. not using your brakes), weight is only a second-order MPG effect. You need a longer pulse but you get a longer glide.
Some members of this forum have reported higher MPG with increased weight, because it fits the pulse & glide cycles of their commute better.
Aerodynamics, tire rolling resistance, and engine efficiency are first-order effects.
The Following User Says Thank You to dennyt For This Useful Post:
04-18-2011, 04:24 PM
And yet still, it's fun to see just how light you can make a car without making it structurally unsafe.
04-18-2011, 04:27 PM
#9 (permalink)
dude...wait...what?
thats a really good idea and i bet it could be done pretty simply
82 rx7 diesel
82 300d diesel
84 b2200 diesel
All veggie, all the time!
#10 (permalink)
Yes ^
I miss my 1989 CRX Si so day-um bad, I miss only weighing like 2100 pounds  This car weights like 2900 so If I can loose some of that and get closer to the CRX im happy... Too bad I cant throw a 1.5 liter engine in this car
