03-12-2011, 05:09 PM
This thread is in the EcoModder Project Library |
T-100 Road Warrior
Pool noodle mustache...
One more quick stick on before I gas up and go...
$1 Pool noodle attached on the front and rear with Gorilla tape. Shouldn't be a problem if it scrapes a little...
Clearance from the ground is 5½".
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
03-12-2011, 05:44 PM
Hmmm.... pool noodles. that might be exactly what I need to fill all the holes in my bumper.
03-12-2011, 05:48 PM
Pokémoderator
SuzukiSteve -
Yes, I have seen the "inner grill block" of pool noodles as well, but I hadn't thought of this them as air dams. I usually use dark-colored pipe insulation for grill blocks.
What came first, the pool noodle or the pipe insulation?
CarloSW2
03-13-2011, 02:31 PM
T-100 Road Warrior
Mustache only made it through one tank before it got "lost"...
However on the other side of it...got my best ever from Houston to Ardmore...26.98mpg! This run is usually around 21-23mpg.
So now I have this crazy idea fer an adjustable air dam. Something that I can pivot down fer highway speeds but allow it to bump up when it comes to obstacles. I might use another noodle fer the test material but eventually move on to something longer and durable.
The Following User Says Thank You to BamZipPow For This Useful Post:
03-13-2011, 05:32 PM
Wiki Mod
I might be interested in making a copy if it works
03-13-2011, 05:44 PM
adjustable airdams have been thought of, but i think you're better of in the real world with something that can stand up to the abuse.
the gm volt seems to go that route too.
you might want to look at linoleum, vinyl or a similar flooring material, places that sell and place the stuff might have undesized leftovers you can have or they sell for very little don't look at the color, a shot of black spray paint will render it invisible... something that's undersized as a flooring marterial can still be several square meters, and it's pretty strong. some types are brittle but others will flex so hitting something won't be a problem and at worst it'll grind away where it hits.. i'd secure it with self tapping wood screws into the back or the bottom of the plastic bumper leaves a tiny hole that noone will ever see in case you end up.
considdering the potential savings you can spend a few dollars on decent material and have the mod pay for itself over a relative short time
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
The Following User Says Thank You to lunarhighway For This Useful Post:
03-13-2011, 06:58 PM
Conveyor belting ain't cheap or easy to fabricate, but is impervious to road kill and parking curbs.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
The Following User Says Thank You to Big Dave For This Useful Post:
03-14-2011, 10:57 AM
T-100 Road Warrior
I was thinking like a visor setup similar to a helmet visor. Lift when you don't need it, drop it down when you do. Have the pivot points near the front wheel well with a cable to activate the air dam.
Thinking about testing it out with some strips of Coroplast to see how well it performs/works. No big loss if it gits eaten up or broken.
03-14-2011, 12:38 PM
#9 (permalink)
Wiki Mod
Sounds like a plan to.me. lots of pictures please
03-14-2011, 02:34 PM
#10 (permalink)
Aero Wannabe
Rubber baseboard for use in kitchens comes in colors including black. It is cheap and flexible and already the right color for your vehicle.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
https://ecomodder.com/forum/showthre...tml#post621801
The power needed to push an object through a fluid increases as the cube of the velocity. Mechanical friction increases as the square, so increasing speed requires progressively more power.
The Following User Says Thank You to COcyclist For This Useful Post:
