Old 06-07-2008, 05:45 PM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Got a few swap questions (help vxers?)
The first question is this: What should I do about the fuel line? Where it attaches to the banjo bolt, it's different. Kinda hard to see, but one side is the same and the other is more open on the one I had compared to the one that came with the engine (And came cut in half):
Also, does the US VX have a second o2 sensor? Should I just ignore this one?
Thanks for the helpzors.
ID:	888   Click image for larger version
ID:	889   Click image for larger version
ID:	890   Click image for larger version
Old 06-07-2008, 11:05 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Bumpsky
Old 06-07-2008, 11:14 PM   #3 (permalink)
Red
Red's Avatar
Maybe one of those fuel lines is for the return?
Old 06-08-2008, 02:17 AM   #4 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Ford Thunderbird
90 day: 27.75 mpg (US)
Cut your good one in half and braze them together...
If it looks like it'll leak if you use your old one, I'd either make a visit to majestic honda or a local junkyard. I have no idea though, sorry.
Also, I thought the VX just had one (really expensive) O2 sensor. Majestic honda usually posts parts diagrams, so you could figure it out that way...
- LostCause
Old 06-08-2008, 12:03 PM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
Those fuel lines are both for the incoming, we'll have to see if honda stocks the part. I might have one in my basement, too, who knows...I know I've gone through several of them...
Good idea on checking majestic, will do.
Old 06-08-2008, 03:34 PM   #6 (permalink)
Nden's Avatar
Send a message via MSN to Nden Send a message via Yahoo to Nden
Try reversing the line, its what I had to do with my VX. the EGR is in the way. Or if a wrecking yard is near you, see which 1s will reach/good angle for u. wus up with them vx injectors? =)
If you don't know your rights, its like you don't have any at all. Pre Paid Legal & ID Theft Services Restoration available... check out
http://www.deantaber.com
Old 06-08-2008, 05:33 PM   #7 (permalink)
Dartmouth 2010
SVOboy's Avatar
I think I found a line that might work in the basement...
Send me an email at benjamin.jones@ecomodder.com with what you need and I'll hit you back asap.
Old 06-08-2008, 10:10 PM   #8 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
the O2 sensor in the middle of the exhaust manifold is the only one in the CX/VX
The diff is that the VX uses the 'spensive wideband one.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 06-08-2008, 10:15 PM   #9 (permalink)
Dartmouth 2010
SVOboy's Avatar
Yeah, I checked majestic...in japan they evidently had two o2s, which is what most cars have these days.
Good old honda, ahead of it's time and all. Just going to leave the other o2 in to block the hole.
Blackfly XFi? Geo Metro economy cam shaft swap! Update: swap completed MetroMPG EcoModding Central 31 11-09-2014 05:28 PM
Mopar to offer Diesel Swap kit for Wranglers Red EcoModding Central 8 08-09-2011 06:23 PM
Just a couple of questions... 97Cavalier General Efficiency Discussion 2 06-05-2008 10:31 AM
VX swap questions reformed EcoModding Central 7 03-05-2008 08:24 AM
HX powerplant swap... worth it? reformed EcoModding Central 6 02-03-2008 04:00 PM
