Old 11-14-2010, 03:55 PM   #11 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
an 86 VW is not going to have OBDII, so UG and SG are out. The new Garmins that have OBDII capabilities won't work either.
You can keep your eye out on Craigslist for a GPS. You should be able to get one cheap enough. You may never use the added capabilities, but they are handy.
The bike speedometer is a good choice too. You say it had one in it until last week, so you must be all wired up and ready to go... that would be the cheapest option, and you may be able to find one on Craigslist even cheaper than in a store.
Old 11-15-2010, 09:14 AM   #12 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by SentraSE-R View Post
I'm not up on the technology, but I'm guessing the cheaper bike speedometers use a magnetic sensor on the forks or frame, and a magnet on the spokes. Ergo they'd be a PITA to install on a car.
They've been used on motorcycles, so there's no real reason why they wouldn't work on a car.
A bigger magnet can be used if the distance between magnet and sensor gets too large.
Some don't go beyond 99 mph or kph though.
Old 11-16-2010, 09:42 AM   #13 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I appreciate everyones thoughts. I had a bike speedometer that lasted about 7000 miles before the reed switch disintegrated.
I have a plan now. I got a Garmin foretrex. It is powered by two AAA batteries. I am going to build a powersupply so that I can power it from my car.
Noah Webster, 1787
Old 11-16-2010, 07:10 PM   #14 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
I have a 2 yr old garmen. It is the cheapest unit made but it works. euromodder's pic is of a better model but the display is the same numbers.
Mine is powered from a 12 volt outlet.
They run about $89 new and a used one should be cheep. Also look for a black Friday deal.
Old 11-16-2010, 07:13 PM   #15 (permalink)
Wiki Mod
Old 11-23-2010, 12:54 PM   #16 (permalink)
Do more with less
I got my KA317, the solid state voltage regulator in the mail today, bought 10 of them on fleabay for 3 dollars including shipping. I built up and tested my circuit. Success, a solid 2.7 volts from car voltage (12-14 volts). Here is the circuit.
I used some resistors I had laying around r1=150 ohm and r2 a fixed 180 ohm. I am going to pot it in a small plastic box. I have a wooden dowel that I am going to use to make spacers for the battery simulator. Will get a picture of it.
Edit: changed Resistor values
Noah Webster, 1787
Old 11-23-2010, 03:18 PM   #17 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Cool!
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 11-23-2010, 10:31 PM   #18 (permalink)
Do more with less
Here is my voltage regulator hooked up to my Garmin. I used a couple of dowel rods to replace the AAA cells. I have tested it with 7 to 14 volts and the Garmin shows 3 bars.
I ran it for 15 minutes with the light on and noticed that that chip got hot so I added a rather large heat sink before I potted it. I need to connect it a switched circuit of the electrical system. Also mount the GPS to the dashboard.
Noah Webster, 1787
VSS signal for GPS speedomoter kane66 Instrumentation 1 11-24-2010 10:49 AM
GPS Navigation Saves Gas Through More Efficient Route Selection SVOboy EcoModder Blog Discussion 0 05-04-2009 11:50 AM
Mounting 3d party GPS bwilson4web Instrumentation 8 04-13-2009 01:53 PM
