Old 12-04-2010, 10:07 AM   #1 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
First Post! 06 Pontiac GP
Hi
Let me tell you a little about myself. I've been driving since gas was 45 cents a gallon. When I started driving I un-ecomodded cars. Although some of the thing we did improved gas mileage if only slightly, it was not our goal.
Fast forward. My current car is a 06 Gran Prix. With a 30 MPG highway rating not bad. Have been at 28 to 29, found I have a front brake problem or it would have been higher. It is not a daily driver like a lot of your cars, so in need inexpensive mods that work and not a lot of testing because my main method of saving gas is keep it parked. So all you GP ownesr I will be looking for your help. And if I ask the same question one thousand newbie have asked have patience and please point me in the right direction.
And my first question shouldn't the front air dam be below the lowers sub frame?
Old 12-04-2010, 10:35 AM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Welcome!
Have you looked at our wiki yet for mod ideas?
Car MPG Efficiency Modifications Main - EcoModder
As for the air dam, yes it should be lower then the under side of the car.
The Following User Says Thank You to Weather Spotter For This Useful Post:
nemo (12-05-2010)
Old 12-05-2010, 07:45 AM   #3 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Welcome! I've worked on most all generations of GP - a 92, 99, 00, and 06 myself. While I may not be able to answer everything, I can try!
The Following User Says Thank You to Nevyn For This Useful Post:
nemo (12-05-2010)
2006, gran prix, pontiac
Token expired and killed my post. Bad Token! orange4boy Forum News & Feedback 12 01-27-2010 02:43 AM
Hub cap drag versus weight and heat bryan11 Aerodynamics 7 01-13-2010 02:37 AM
EcoModder 100,000th Post Giveaway Spectacular!!! SVOboy Forum News & Feedback 35 05-09-2009 01:58 PM
"Start New Thread" icon at bottom of each post??? TestDrive Forum News & Feedback 5 03-17-2009 04:09 PM
Battery Post Repair bennelson Fossil Fuel Free 4 10-17-2008 03:35 AM
