Old 11-28-2010, 03:42 PM   #11 (permalink)
Originally Posted by BHarvey View Post
Made my first template for the block, now I need a clear material that is bendable but pretty rigid and a good way to install the blocks, IE aesthetics in mind.
I used aluminum trim coil to make the grille blocks for my '09 Aveo. It's extremely light, easy to cut and easy to bend; it can be fastened using screws and tinnerman nuts.
The lower grill block is behind the lower grille and is invisible, permanently mounted, painted black. The upper grille block is also painted black and is attached externally by two long screws through the grille. It is only attached in winter as it would be too restrictive for summer temps.
Grille blocks will help the car warm up a bit faster. However, aerodynamically it had no effect on the car's FE, nor did the front belly pan I made.
Old 11-28-2010, 10:22 PM   #12 (permalink)
Aveo - '08 Chevolet Aveo LS
front bellypan did nothing? thats sad
Old 11-28-2010, 10:58 PM   #13 (permalink)
IMHO aero mods are vastly overrated. I have yet to see things like grille blocks, belly pans, or modified wheel covers and side mirrors improving fuel economy to any noticeable degree.
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Grill Block Summary 4536 Aerodynamics 19 07-22-2010 11:55 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
