Old 03-17-2009, 09:00 PM   #11 (permalink)
Hi,
That looks a lot closer to what may work. You may want to err on the side of not blocking enough at first, and see how it goes -- and if it is cool enough, block a little more?
Old 03-17-2009, 09:17 PM   #12 (permalink)
Racer XD - '06 Hyundi Elantra GT
90 day: 33.26 mpg (US)
Racer XD 2013 - '06 Hyundi Elantra GT
90 day: 31.48 mpg (US)
Racer XD 2014 - '06 Hyundi Elantra GT
Racer XD 2012 - '06 Hyundi Elantra GT
Racer XD 2011 - '06 Hyundi Elantra GT
That will no work. Because if I cut the plexie glass I can't put it back together. That is why I am starting with the bumper then grill.
2006 Hyundai Elantra GT 2.0L (Manual)
Weapon-R secret weapon intake with ram air kit ScanGauge Belly Pan
http://www.cars.com/ City 27 mpg - Highway 34 mpg
http://www.fueleconomy.gov/ City 23 mpg - Highway 31 mpg - Combined 26 mpg
Old 03-17-2009, 09:20 PM   #13 (permalink)
Hi,
What if you continue the test with tape a little longer? That way you can experiment.
Old 03-17-2009, 09:25 PM   #14 (permalink)
That is a good idea. I will try that.
Old 03-18-2009, 09:52 PM   #15 (permalink)
OCD Master EcoModder
brucepick's Avatar
Outasight - '00 Honda Insight
Gen-1 Insights
90 day: 54.18 mpg (US)
My finding was, I need to have an adjustable grill block. I watch the water temp on the ScanGauge. I used chunks of foam pipe insulation. Usually several pieces duct taped together to fill the open gaps in the grill.
For really cold days, say below 10ºF, a tiny opening about 3x6 inches is enough. Maybe don't even need that in very cold weather.
Now with temps between 60-70, I need about three openings that size. I know I'll need more when it gets warmer in summer.
In my case the smaller grill opening increases under-hood temps which supplies my warm air intake.
Coast long and prosper.
Old 03-19-2009, 05:50 AM   #16 (permalink)
Hi Bruce,
I think that the location of the opening greatly affects the effectiveness. You should be fine with the whole upper grill blocked (and with the edge of the hood sealed). I think leaving the center of the lower grill open will be the most effective with the smallest opening; or at least that is how it works on my xA:
Old 03-19-2009, 07:07 AM   #17 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 Honda City iDSI EXi
90 day: 47.47 mpg (US)
One stupid question: Do you EOC? Is the overheating in spite of EOC? (checking applicability of this caution in my particular case, so will appreciate an answer).
Also I saw an MPGuino-actuated grille block some days ago on this forum somewhere.. will it help you?
aero, block, grill, heat, temp
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 41 02-27-2014 09:22 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
I got worse fuel mileage with a grill block bombloader Aerodynamics 14 02-10-2009 04:16 AM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
